[SOLVED] Custom performance vector
User: "cliftonarms"
New Altair Community Member
Updated by Jocelyn
I need : a way to create a custom performance figure that can be passed to the (per) output of an "Optimise Parameter ( Evolutionary )" block.
My problem is : after applying my model I have to create a complex custom performance figure  e.g. a simple float value of 14.6
How can I convert this performance number into a performance vector that will then allow me to encase the entire process within a parameter optimization block.
Thank you in advance for your help.
1 - 1 of 11
    User: "cliftonarms"
    OP
    Found it
    Use : Extract Performance
    Set : performance type to data value and attribute name to the attribute you wish to use.
