incompatible with SQLite???
Hi,
I would like to use "Stream Database' operator to feed data to my module in RapidMiner. So I first got a SQLite JDBC Drive from here
http://rapid-i.com/rapidforum/index.php/topic,2449.0.html
And successfully install it on my RapidMiner through 'Manage Database Drivers' dialog.
Also, a new database connection was added through "Manage Database Connections' dialog. When I press the "Test' button, the connection status shows 'Connection OK'.
However, after I add a "Stream Database" to my 'Process' and then run it, I got an error message:
Process Failed
"Database error occured: SQLite only supports TYPE_FORWARD_ONLY cursors"
Reason: SQLite only supports TYPE_FORWARD_ONLY cursors
Offending operator: Stream Database
Forward-only-cursor probably is the only type of cursor supported by SQLite. (Precisely speaking, SQLite does not actually have cursors. But SQLite behaves like having a forward only cursor).
So, is SQLite really incompatible with RapidMiner? If not, then how could I bypass this error?
BTW, I searched the forum and found these two relevant topics
sqlite db import: http://rapid-i.com/rapidforum/index.php/topic,2449.0.html
Using SQLite DB with RM: http://rapid-i.com/rapidforum/index.php?topic=3581.0
Unfortunately, they couldn't provide any help in my case.
Thanks.
Process Failed
Thanks.
1 - 3 of
31
Hi Marius,
Thanks for the quick reply.
Yes, I tried 'Read Database' operator and it did its job pretty well in my test run. Unfortunately, there are much more than 5 million records in my data set. If I want to analyze this data without using 'Stream Database" operator, I probably have to upgrade my current hardware or apply some ML tricks (e.g. split/resample the dataset manually).
Anyway, just want to know if I can use SQLite in 'Stream Database' operator or not. If there is no quick fix for this issue, then I will seek other alternative solutions or options.
Thanks for the help again.
Yi-Chien
Yi-Chien
Marius wrote: Marius wrote: Marius wrote:
Did you try Read Database? That's probably sufficient for your use case.
Best regards,
Marius
Best regards,
Marius
