Free memory operator does not work
Folks,
I finally made a logging for every db read I make and the free memory operator passes through so quickly and not even two seconds is spent in the operator when I see the timing in my logfile but the memory was rising and reaching a peak. I think it does not work correctly. I am clogged with memory issues running my experiments, need your advice for workaround
. I cannot do a FP Growth for one set and then other set because ultimately -I need the combined dataset for association rule generation which is again a problem for a huge data set, I have tried it logging from CSV but it does not work
I love rapidminer tool as an wonderful idea but the memory issues
God
