Hi!
As I'm trying to process documents from files and extract information, I use Xpath. Slovenian language has some special characters. Xpath in RapidMiner doesn't seem to recognize these character especially when I search for the elements.
What is the solution?
U.
How are you retrieving the data? Does the respective operator have an "encoding" parameter? If yes, please make sure that you selected the correct encoding, i.e. the same as used in your input data.
Best regards,
Marius
