🎉Community Raffle - Win $25
Join and Win
Error using Set Role in Rapid Analytics
marcozUser: "marcoz"
New Altair Community Member
Updated by Jocelyn
Hi,
I have created a process using "set role" block inside. In local rapid miner, the process correctly works but when I run it on rapid analytics server the process fails with the following error:
com.rapidminer.operator.UserError: The attribute '' does not exist.
Please, Could anybody help me ? Thanks.
1 - 2 of 21
    Hi,
    I faced the same issue today. I print the xml for the set role operator in my java code,
    Operator op = process0.getOperator("Role_test");
    System.out.println("c "+op.getXML(false));
    I found that the attribute name is missing in the xml even if the property "attribute name" set from the Rapidminer GUI.
    so I set the attribute from my java code and the problem sloved
    process0.getOperator("Role_test").setParameter("name", "icd_code");
    Hope this helps
    Ciju George
    OP
    Yes, I'm interested ,
    can you tell me where you found this xml?
    thanks
