[SOLVED]Problem with Config file for Read Server Log
Hi,
I have a log file in the following format:
112.135.255.32 - [06/Apr/2013:23:55:07 +0530] "POST /SVRClientWeb/ActionController HTTP/1.1" 200 14107 "https://www.example.com/SVRClientWeb/ActionController?sblparam=Z6spFdlqDbbbgtECSSpzHGTShMYdnVO7D7KyPZZBEmpeZSPuP20Ky7zr9jZXl1rnj+s5lCszddZe QtctW6Q5og==" "Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.31 (KHTML, like Gecko) Chrome/26.0.1410.43 Safari/537.31" POST /SVRClientWeb/ActionController - HTTP/1.1 www.example.com
For the Read Server Log in Rapid Miner I have downloaded the two config files available at
http://sourceforge.net/p/polliwog/feature-requests/5/
But the process get stuck and stop running? I feel that these config files do not match with my log file format? How to solve my problem. Thanks in advance!
1 - 9 of
91
Thanks Marius!That will be a great help.
Please find the sample of my log file here.
https://www.dropbox.com/s/ynbfvig86hyxdka/logfile
I changed my log file according to the IIS log file Format : http://sourceforge.net/p/polliwog/feature-requests/5/
But it also didn't work. Has anybody tried using an IIS log file with RapidMiner??
Please use the sample log file here :
https://www.dropbox.com/s/r02kc4l1aq98msk/ex121127.log
I used following config file:
https://www.dropbox.com/s/66u36j2sr77tu3w/w3c-iis7-addl-extended-log-entry-format.xml
Thanks Marius!
Thanks Marius!
Hi Marius!
I have done lot of editing to both log files and to config files. Still couldn’t find a way to solve this. At first I removed the bytes sent part from the config file. Once it failed then i added a bytes sent to column to the logfile. After I entered column names to the log file according to the config file. Everything produces the same result as follows. The program get stuck and I have to use kill command in terminal to exit.
https://www.dropbox.com/s/anati514awfboei/Screenshot%20from%202013-06-28%2018%3A17%3A03.png
One other thing I'm using Rapidminer in Ubuntu 12.04. For Apache log files this works fine and I can get results. Problem is with the IIS log files.
Have you tried this with my log files?
Best regards,
Marius
