<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.005" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="120"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="write_csv" compatibility="5.3.005" expanded="true" height="76" name="Write CSV" width="90" x="514" y="120"> <parameter key="csv_file" value="C:\a.txt"/> <parameter key="column_separator" value="|"/> <parameter key="quote_nominal_values" value="false"/> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Write CSV" to_port="input"/> <connect from_op="Write CSV" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="write_csv" compatibility="5.3.008" expanded="true" height="76" name="Write CSV" width="90" x="380" y="75"> <parameter key="csv_file" value="/home/macphotobiker/Desktop/tsv.tsv"/> <parameter key="column_separator" value="	"/> </operator> <connect from_op="Write CSV" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
