🎉Community Raffle - Win $25
Join and Win
Add leading Zeros
User: "xDSticker"
New Altair Community Member
Updated by Jocelyn
Dear Dataminers,
I try to add leading zeros to the numbers within an attribut. Is there any way to do so?
I tried to find a regualr expression but couldn't find a solution :(
Thank you for your time
Sticker
1 - 1 of 11
    User: "MariusHelf"
    It's not thaaat easy, but it is possible. First of all, you have to convert the numerical attribute into a nominal attribute with Numerical to Polynominal. Then you have to create several regular expressions. For 3-digit values in the form:
    ^(\d)$ -> 00$1
    ^(\d\d)$ -> 0$1
    The caret specifies that the expression must be matched at the beginning of the string, the dollar stands for the end of the string. Both together require an exact match.
    Best regards,
    Marius
