"Generate Series"
New Altair Community Member
Updated by Jocelyn
I want to generate some series so that I can illustrate transformations, visualizations etc. However, the operator Generate Series (Sinus) and as well the Generate Data (Series) successfully deliver 0 single attributes / series, the value dimension is 0 and so I don't see anything.
How can I get 1 or 2 attributes that change over time?
Can I tell, how 2 sine curves should be combined to form a more interesting cure?
Thanks in advance!
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.3.007">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="series:generate_series_sinus" compatibility="5.2.000" expanded="true" height="60" name="Generate Series (Sinus)" width="90" x="45" y="165">
<list key="frequency">
<parameter key="5.0" value="3.0"/>
</list>
</operator>
<operator activated="true" class="series:visualize_series" compatibility="5.2.000" expanded="true" height="60" name="Visualize Series" width="90" x="246" y="165"/>
<connect from_op="Generate Series (Sinus)" from_port="output" to_op="Visualize Series" to_port="series"/>
<connect from_op="Visualize Series" from_port="series" to_port="result 1"/>
</process>
</operator>
</process>
Thanks in advance!
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</operator>
</process>
</operator>
</process>
1 - 2 of
21
Hi Katharina,
you don't need the Visualize Series operator, just connect the series data to the process output, and in the standard results view you can inspect the series data: just switch from Meta Data View to Plot View, and in the upper left select dim_1 from the list.
To superpose 2 sine curves, you have to enable expert mode, then you can configure the frequency and amplitude of each component in the frequency parameter of the Generate Series (Sinus) - see process below.
You may have to update your Series Extension to the latest version 5.3.0.
<process version="5.3.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
<operator activated="true" class="series:generate_series_sinus" compatibility="5.3.000" expanded="true" height="60" name="Generate Series (Sinus)" width="90" x="45" y="30">
<parameter key="50.0" value="0.5"/>
</list>
</operator>
<connect from_op="Generate Series (Sinus)" from_port="output" to_port="result 1"/>
</process>
</operator>
</process>
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="generate_data" compatibility="5.3.007" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
<operator activated="true" class="series:data_to_series" compatibility="5.2.000" expanded="true" height="60" name="Data To Series" width="90" x="246" y="30">
<parameter key="series_attribute" value="att1"/>
</operator>
<operator activated="true" class="series:visualize_series" compatibility="5.2.000" expanded="true" height="60" name="Visualize Series" width="90" x="447" y="30"/>
<connect from_op="Generate Data" from_port="output" to_op="Data To Series" to_port="example set"/>
<connect from_op="Data To Series" from_port="series" to_op="Visualize Series" to_port="series"/>
</process>
</operator>
</process>
