🎉Community Raffle - Win $25
Join and Win
[SOLVED] Rolling Up Data
User: "maccten"
New Altair Community Member
Updated by Jocelyn
Hi,
I have data that looks something like below
id attr1 attr2, attr3
a  0         1       0
a  1         0       0
a  0         0       0
a  0         0       1
I m using K-means to cluster this data but i want to cluster the IDs together so for example a,b,c would be clustered together because their attributes are the same
At the moment this isnt working as k-means is treating each row as a record as opposed to each id as a record
To get around this i was hoping that i could collapse four records (a single ID) onto one line
So for example
id, attr1, attr2, attr3
a     1       1        1
Is this possible within Rapidminer?
Thanks for your help
1 - 1 of 11
    User: "maccten"
    OP
    Hi,
    The trick to fixing this problem was to use the aggregate operator and set the aggregation property to MAX around the label i wanted to roll up to in this case the ID
    Thanks
