Rapidanalytics Proxy Settings
Hi,
my RA Server runs in an internal network but needs/can get outside access via a proxy.
But I am wondering what are the correct settings (in the RA gui) to apply for this to work.
I tried:
ftp.proxyHost = proxy.server.at
ftp.proxyPort = proxy.server.at
ftp.proxySet = true
http.proxyHost = proxy.server.at
http.proxyPort = proxy.server.at
http.proxySet = true
https.proxyHost = proxy.server.at
https.proxyPort = proxy.server.at
https.proxySet = true
socksProxyHost = proxy.server.at
socksProxyPort = proxy.server.at
in several variations (without socks and empty string instead of "true") but neither seems to work.
Also modifying the run.config with the -DproxySet=true -DproxyHost=.. creates an "infinite memory leak" situation in my setup.
So what is the correct way to this?
I tried:
ftp.proxySet = true
1 - 2 of
21
Hi,
the settings are the same as in RapidMiner. So when RapidMiner can connect to the outside world via Proxy, the same settings should work for RapidAnalytics.
However the settings need to be added to the Java launch options, otherwise they will not work.
Once the correct settings are known, you need to edit the configuration file in the RapidAnalytics folder.
On Windows, edit the file bin\run.conf.bat. The last line should read
:JAVA_OPTS_SET
Before that line, add two lines saying
set JAVA_OPTS="%JAVA_OPTS% -Dhttp.proxySet=true -Dhttp.proxyHost=host -Dhttp.proxyUsername=user -Dhttp.proxyPassword=password"
set JAVA_OPTS="%JAVA_OPTS% -Dhttps.proxySet=true -Dhttps.proxyHost=host -Dhttps.proxyUsername=user -Dhttps.proxyPassword=password"
On Linux and Unix, you should edit the file bin/run.conf. At the end, add two lines
JAVA_OPTS="$JAVA_OPTS -Dhttp.proxySet=true -Dhttp.proxyHost=host -Dhttp.proxyUsername=user -Dhttp.proxyPassword=password"
JAVA_OPTS="$JAVA_OPTS -Dhttps.proxySet=true -Dhttps.proxyHost=host -Dhttps.proxyUsername=user -Dhttps.proxyPassword=password"
Regards,
Marco
:JAVA_OPTS_SET
Regards,
Marco
But still did anybody use RA behind a proxy and got outside? I am trying to use RM for a project that might be getting a lot bigger but without outside access the usability is greatly/nearby fataly reduced.
