🎉Community Raffle - Win $25
Join and Win
Rapidanalytics Proxy Settings
User: "simons"
New Altair Community Member
Updated by Jocelyn
Hi,
my RA Server runs in an internal network but needs/can get outside access via a proxy.
But I am wondering what are the correct settings (in the RA gui) to apply for this to work.
I tried:
ftp.proxyHost = proxy.server.at
ftp.proxyPort = proxy.server.at
ftp.proxySet = true
http.proxyHost = proxy.server.at
http.proxyPort = proxy.server.at
http.proxySet = true
https.proxyHost = proxy.server.at
https.proxyPort = proxy.server.at
https.proxySet = true
socksProxyHost = proxy.server.at
socksProxyPort = proxy.server.at
in several variations (without socks and empty string instead of "true") but neither seems to work.
Also modifying the run.config with the -DproxySet=true -DproxyHost=.. creates an "infinite memory leak" situation in my setup.
So what is the correct way to this?
1 - 2 of 21
    User: "simons"
    OP
    So I looked source for the RapidMiner.Init method, my property names seem correct.
    But still did anybody use RA behind a proxy and got outside? I am trying to use RM for a project that might be getting a lot bigger but without outside access the usability is greatly/nearby fataly reduced.
    User: "Marco_Boeck"
    Hi,
    the settings are the same as in RapidMiner. So when RapidMiner can connect to the outside world via Proxy, the same settings should work for RapidAnalytics.
    However the settings need to be added to the Java launch options, otherwise they will not work.
    Once the correct settings are known, you need to edit the configuration file in the RapidAnalytics folder.
       On Windows, edit the file bin\run.conf.bat. The last line should read
       :JAVA_OPTS_SET
       Before that line, add two lines saying
       set JAVA_OPTS="%JAVA_OPTS% -Dhttp.proxySet=true -Dhttp.proxyHost=host -Dhttp.proxyUsername=user -Dhttp.proxyPassword=password"
       set JAVA_OPTS="%JAVA_OPTS% -Dhttps.proxySet=true -Dhttps.proxyHost=host -Dhttps.proxyUsername=user -Dhttps.proxyPassword=password"
       On Linux and Unix, you should edit the file bin/run.conf. At the end, add two lines
       JAVA_OPTS="$JAVA_OPTS -Dhttp.proxySet=true -Dhttp.proxyHost=host -Dhttp.proxyUsername=user -Dhttp.proxyPassword=password"
       JAVA_OPTS="$JAVA_OPTS -Dhttps.proxySet=true -Dhttps.proxyHost=host -Dhttps.proxyUsername=user -Dhttps.proxyPassword=password"
    Regards,
    Marco
