HTTP Status 404 - /RA/faces/restricted/index.xhtml
Hi.
I followed the manual but this is the result:
type Status report
message /RA/faces/restricted/index.xhtml
description The requested resource (/RA/faces/restricted/index.xhtml) is not available.
JBoss Web/3.0.0-CR1
I checked the forum for similar errors, but no solution worked. I'm out of ideas. Has anybody any idea what's going on?
2013-05-03 16:14:45,363 ERROR [ProfileServiceBootstrap] (Thread-2) Failed to load profile:: org.jboss.deployers.client.spi.IncompleteDeploymentException: Summary of incomplete deployments (SEE PREVIOUS ERRORS FOR DETAILS):
DEPLOYMENTS IN ERROR:
Deployment "jboss.web.deployment:war=/RA" is in error due to the following reason(s): org.jboss.deployers.spi.DeploymentException: URL file:/home/kruh/PROGS/RapidAnalytics/server/default/tmp/vfs/automount6807f6966d262243/RapidAnalytics_War.war-e6f6c7b0b22c1b8/ deployment failed
at org.jboss.deployers.plugins.deployers.DeployersImpl.checkComplete(DeployersImpl.java:1228) [:2.2.0.GA]
at org.jboss.deployers.plugins.main.MainDeployerImpl.checkComplete(MainDeployerImpl.java:905) [:2.2.0.GA]
at org.jboss.system.server.profileservice.deployers.MainDeployerPlugin.checkComplete(MainDeployerPlugin.java:87) [:6.0.0.Final]
at org.jboss.profileservice.deployment.ProfileDeployerPluginRegistry.checkAllComplete(ProfileDeployerPluginRegistry.java:107) [:0.2.2]
at org.jboss.system.server.profileservice.bootstrap.BasicProfileServiceBootstrap.start(BasicProfileServiceBootstrap.java:135) [:6.0.0.Final]
at org.jboss.system.server.profileservice.bootstrap.BasicProfileServiceBootstrap.start(BasicProfileServiceBootstrap.java:56) [:6.0.0.Final]
at org.jboss.bootstrap.impl.base.server.AbstractServer.startBootstraps(AbstractServer.java:827) [jboss-bootstrap-impl-base.jar:2.1.0-alpha-5]
at org.jboss.bootstrap.impl.base.server.AbstractServer$StartServerTask.run(AbstractServer.java:417) [jboss-bootstrap-impl-base.jar:2.1.0-alpha-5]
at java.lang.Thread.run(Thread.java:722) [:1.7.0_21]
2013-05-03 16:14:45,391 INFO [org.apache.coyote.http11.Http11Protocol] (Thread-2) Starting Coyote HTTP/1.1 on http-19853
2013-05-03 16:14:45,396 INFO [org.apache.coyote.ajp.AjpProtocol] (Thread-2) Starting Coyote AJP/1.3 on ajp-0.0.0.0-8009
2013-05-03 16:14:45,398 INFO [org.jboss.bootstrap.impl.base.server.AbstractServer] (Thread-2) JBossAS [6.0.0.Final "Neo"] Started in 1m:19s:401ms
2013-05-03 16:18:00,921 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] (HDScanner) Error installing to Real: name=vfs:///home/kruh/PROGS/RapidAnalytics/server/default/deploy/rapidanalytics-ds.xml state=PreReal mode=Manual requiredState=Real: org.jboss.deployers.spi.DeploymentException: Error deploying: jboss.jca:service=ManagedConnectionFactory,name=jdbc/RapidAnalyticsDS
at org.jboss.deployers.spi.DeploymentException.rethrowAsDeploymentException(DeploymentException.java:49) [:2.2.0.GA]
at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:125) [:6.0.0.Final]
at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:49) [:6.0.0.Final]
at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) [:2.2.0.GA]
at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:55) [:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:179) [:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1832) [:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1550) [:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1571) [:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1491) [:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:379) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:2044) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:1083) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.executeOrIncrementStateDirectly(AbstractController.java:1322) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1246) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1139) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:939) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:654) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployersImpl.change(DeployersImpl.java:1983) [:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:1076) [:2.2.0.GA]
at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:679) [:2.2.0.GA]
at org.jboss.system.server.profileservice.deployers.MainDeployerPlugin.process(MainDeployerPlugin.java:106) [:6.0.0.Final]
at org.jboss.profileservice.dependency.ProfileControllerContext$DelegateDeployer.process(ProfileControllerContext.java:143) [:0.2.2]
at org.jboss.profileservice.deployment.hotdeploy.HDScanner$HDScanAction.deploy(HDScanner.java:240) [:0.2.2]
at org.jboss.profileservice.deployment.hotdeploy.HDScanner$HDScanAction.complete(HDScanner.java:192) [:0.2.2]
at org.jboss.profileservice.management.TwoPCActionWrapper.doComplete(TwoPCActionWrapper.java:57) [:0.2.2]
at org.jboss.profileservice.management.actions.AbstractTwoPhaseModificationAction.complete(AbstractTwoPhaseModificationAction.java:74) [:0.2.2]
at org.jboss.profileservice.management.actions.AbstractTwoPhaseModificationAction.prepare(AbstractTwoPhaseModificationAction.java:95) [:0.2.2]
at org.jboss.profileservice.management.ModificationSession.prepare(ModificationSession.java:87) [:0.2.2]
at org.jboss.profileservice.management.AbstractActionController.internalPerfom(AbstractActionController.java:234) [:0.2.2]
at org.jboss.profileservice.management.AbstractActionController.performWrite(AbstractActionController.java:213) [:0.2.2]
at org.jboss.profileservice.management.AbstractActionController.perform(AbstractActionController.java:150) [:0.2.2]
at org.jboss.profileservice.management.AbstractActionController.perform(AbstractActionController.java:135) [:0.2.2]
at org.jboss.profileservice.deployment.hotdeploy.HDScanner.scan(HDScanner.java:146) [:0.2.2]
at org.jboss.profileservice.deployment.hotdeploy.HDScanner.run(HDScanner.java:90) [:0.2.2]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471) [:1.7.0_21]
at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:351) [:1.7.0_21]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:178) [:1.7.0_21]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:178) [:1.7.0_21]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [:1.7.0_21]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) [:1.7.0_21]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) [:1.7.0_21]
Caused by: java.lang.IllegalStateException: jboss.jca:name=jdbc/RapidAnalyticsDS,service=ManagedConnectionFactory is already installed.
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:835) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:641) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.system.ServiceController.doInstall(ServiceController.java:653) [:6.0.0.Final (Build SVNTag:JBoss_6.0.0.Final date: 20101228)]
at org.jboss.system.ServiceController.install(ServiceController.java:256) [:6.0.0.Final (Build SVNTag:JBoss_6.0.0.Final date: 20101228)]
at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:93) [:6.0.0.Final]
... 41 more
2013-05-03 16:18:00,942 WARN [org.jboss.profileservice.deployment.hotdeploy.HDScanner] (HDScanner) Scan failed: org.jboss.deployers.client.spi.IncompleteDeploymentException: Summary of incomplete deployments (SEE PREVIOUS ERRORS FOR DETAILS):
*** DEPLOYMENTS IN ERROR: Name -> Error
vfs:///home/kruh/PROGS/RapidAnalytics/server/default/deploy/rapidanalytics-ds.xml -> org.jboss.deployers.spi.DeploymentException: Error deploying: jboss.jca:service=ManagedConnectionFactory,name=jdbc/RapidAnalyticsDS
Deployment "vfs:///home/kruh/PROGS/RapidAnalytics/server/default/deploy/rapidanalytics-ds.xml" is in error due to the following reason(s): java.lang.IllegalStateException: jboss.jca:name=jdbc/RapidAnalyticsDS,service=ManagedConnectionFactory is already installed.
at org.jboss.deployers.plugins.deployers.DeployersImpl.checkComplete(DeployersImpl.java:1370) [:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployersImpl.checkComplete(DeployersImpl.java:1316) [:2.2.0.GA]
at org.jboss.deployers.plugins.main.MainDeployerImpl.checkComplete(MainDeployerImpl.java:968) [:2.2.0.GA]
at org.jboss.system.server.profileservice.deployers.MainDeployerPlugin.checkComplete(MainDeployerPlugin.java:82) [:6.0.0.Final]
at org.jboss.profileservice.dependency.ProfileControllerContext$DelegateDeployer.checkComplete(ProfileControllerContext.java:138) [:0.2.2]
at org.jboss.profileservice.deployment.hotdeploy.HDScanner$HDScanAction.deploy(HDScanner.java:246) [:0.2.2]
2013-05-03 16:18:21,019 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] (HDScanner) Error installing to Real: name=vfs:///home/kruh/PROGS/RapidAnalytics/server/default/deploy/rapidanalytics-ds.xml state=PreReal mode=Manual requiredState=Real: org.jboss.deployers.spi.DeploymentException: Error deploying: jboss.jca:service=ManagedConnectionFactory,name=jdbc/RapidAnalyticsDS
... 41 more
2013-05-03 16:18:21,657 WARN [org.jboss.profileservice.deployment.hotdeploy.HDScanner] (HDScanner) Scan failed: org.jboss.deployers.client.spi.IncompleteDeploymentException: Summary of incomplete deployments (SEE PREVIOUS ERRORS FOR DETAILS):
type Status report
JBoss Web/3.0.0-CR1
... 41 more
... 41 more
1 - 13 of
131
Hi.
Yes, I used the latest installer.
I uploaded boot.log at http://pastebin.com/21mrpdMG and server.log at http://pastebin.com/SyxWyF1J
Tnx for any suggestions.
Hi,
the error
If you only have one and the problem persists, please post its contents here.
Regards,
Marco
the error
indicates that there might be something wrong with your *-ds.xml file in the JBOSS/server/default/deploy folder, or that there are multiple such files present (maybe from a previous installation in the same location with a different database?). Can you please see if there are multiple *-ds.xml (e.g. mysql-ds.xml, etc) files present, if so only keep the one which matches the database you are using now.
Regards,
Marco
Hi.
Tnx for your reply. Using default install with the provided installer there are multiple *-ds. xml files in .../server/default/deploy. E.g. hsqldb-ds.xml and mysql-ds.xml.
I followed the manual, renamed both *-ds.xml to *-ds.xml.bck and used the rapidanalytics-mysql-ds.xml.template to create pasted rapidanalytics-ds.xml. The problem persists...
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<datasources>
<local-tx-datasource>
<jndi-name>jdbc/RapidAnalyticsDS</jndi-name>
<rar-name>jboss-local-jdbc.rar</rar-name>
<use-java-context>false</use-java-context>
<connection-definition>javax.sql.DataSource</connection-definition>
<min-pool-size>0</min-pool-size>
<max-pool-size>20</max-pool-size>
<blocking-timeout-millis>30000</blocking-timeout-millis>
<idle-timeout-minutes>30</idle-timeout-minutes>
<prefill>false</prefill>
<background-validation>false</background-validation>
<background-validation-millis>0</background-validation-millis>
<validate-on-match>true</validate-on-match>
<statistics-formatter>org.jboss.resource.statistic.pool.JBossDefaultSubPoolStatisticFormatter</statistics-formatter>
<isSameRM-override-value>false</isSameRM-override-value>
<allocation-retry>0</allocation-retry>
<allocation-retry-wait-millis>5000</allocation-retry-wait-millis>
<security-domain xsi:type="securityMetaData" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
<metadata/>
<local-transaction/>
<prepared-statement-cache-size>0</prepared-statement-cache-size>
<share-prepared-statements>false</share-prepared-statements>
<set-tx-query-timeout>false</set-tx-query-timeout>
<query-timeout>0</query-timeout>
<use-try-lock>0</use-try-lock>
<url-delimiter>|</url-delimiter>
<driver-class>com.mysql.jdbc.Driver</driver-class>
<connection-url>jdbc:mysql://localhost:3306/rapidanalytics</connection-url>
<user-name>rapidanalytics</user-name>
<password>myPassword</password>
</local-tx-datasource>
</datasources>
<datasources>
<metadata/>
</datasources>
I get the same result. You can see from the log files that I changed the location - boot.log http://pastebin.com/7rR2SGiG and server.log http://pastebin.com/tJYgLC5U. The thing still doesn't work...
Hi,
I'm sorry I failed to spot it any earlier
but you are using Java 7. Unfortunately, the current version of RapidAnalytics does not work with that. We are currently migrating it to Java 7 though, so future versions will. So I guess your options currently boil down to either use the latest Java 6 version, or wait for the Java 7 ready version of RapidAnalytics.
Regards,
Marco
Regards,
Marco
I set java6-oracle as the default option on Ubuntu 12.04, reinstalled RA but the result is the same - I get the same http 404. Here's the latest boot.log (http://pastebin.com/AHpTm4iP) and server.log (http://pastebin.com/iMVaw1k4)...
Hi,
I'm sorry but to be honest I have never seen this particular problem before, and there is only so much we can do in the free community support forum :-[
However not everythinig is lost yet as we are currently working on migrating RapidAnalytics to JBoss 7 instead of JBoss 6 as the application server. That will fix quite a few problems (and properly support Java7) and as the architecture of JBoss 7 is fundamentally different to the old JBoss 6 I am certain your particular problem will go away (no more *-ds.xml files for example).
Bad news is I sadly cannot yet give you a release date for the new RapidAnalytics version..
Regards,
Marco
Regards,
Marco
is this the complete boot.log file content? Seems there is something missing in the beginning.
Did you install RapidAnalytics with the installer we provide?
Best,
Nils
