🎉Community Raffle - Win $25
Join and Win
Process Documents from Files - file pattern
User: "CharlieFirpo"
New Altair Community Member
Updated by Jocelyn
Dear all!
I have a folder that contains several different files (different in names and in extensions as well). I want only use the files that contains <text> string in filename. How can I set it in the file pattern parameter using Process Documents from Files operator? If I use *text* , RM does not read any files from the appropriate folder.
Let say I have these filenames: asd_text-fgh.txt, qwe.textrty.xls, ... I think *text* pattern should return these two filenames. Or not?
Thanks for reply!!!
1 - 2 of 21
    User: "venkatesh"
    Thanks for reply!!!
    The pattern is a regular expression *text* will not work. try ".*text.*"
    Here is a sample process for your reference
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.3.007">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="loop_files" compatibility="5.3.007" expanded="true" height="76" name="Loop Files" width="90" x="179" y="75">
            <parameter key="directory" value="/tmp"/>
            <parameter key="filter" value=".*text.*"/>
              <operator activated="true" class="provide_macro_as_log_value" compatibility="5.3.007" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="45" y="30">
                <parameter key="macro_name" value="file_name"/>
              </operator>
              <operator activated="true" class="log" compatibility="5.3.007" expanded="true" height="76" name="Log" width="90" x="447" y="120">
                <list key="log">
                  <parameter key="file_name" value="operator.Provide Macro as Log Value.parameter.macro_name"/>
                </list>
              </operator>
              <connect from_port="file object" to_op="Provide Macro as Log Value" to_port="through 1"/>
              <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log" to_port="through 1"/>
              <connect from_op="Log" from_port="through 1" to_port="out 1"/>
              <portSpacing port="source_file object" spacing="0"/>
              <portSpacing port="source_in 1" spacing="0"/>
              <portSpacing port="sink_out 1" spacing="0"/>
              <portSpacing port="sink_out 2" spacing="0"/>
            </process>
          </operator>
          <connect from_op="Loop Files" from_port="out 1" to_port="result 1"/>
        </process>
      </operator>
    </process>
    OP
    Thank you for reply!
    Your process works for me (returns the expected filenames/paths), but when using the same regular expression at "Process Documents from Files" operator, it does not work :(
    If I use nothing in "file pattern" then my process work properly. But I want it not read all files but only that contains specific string...
