🎉Community Raffle - Win $25
Join and Win
Bolt pretension in radioss
User: "gopal_rathore"
Altair Community Member
Updated by gopal_rathore
Hi,
I am trying to load a bolted structural model and assign pre-tension to the bolt. I have made  a spring element connected between two solid parts of bolt. I can see that pretension can be assigned using spring 13 property and also type 32 spring property. In type 32, what so we mean by Stif0 value? Also how to assign pre-tension using both?
Thank you
1 - 15 of 151
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi Gopal,
    As you can see in the Help menu Stif0 is the spring  stiffness before sensor activation and unloading stiffness after sensor activation. A time sensor is created and and is recalled in the sensor of the property card. As soon as the time specified in the Tdelay is reached the spring will act based on the the force vs displacement function the user specify. This Stif0 value will be the spring stiffness value as soon as the sensor is activated. Please go through RD-T: 3510 Cantilever Beam with Bolt Pretensioner tutorial in Help Menu. I'm attaching a document also oo the RADIOSS elements where pretension spring is also covered.
    You can apply pretesnion in Type 13 spring also. Create a function accordingly and assign the same, that is you can load it from time 0 so that the spring will be under pretension. I'm attaching a sample model file for your reference, In the functions please check the curve defined.
    OP
    Hi,
    The curve is as follow in above files:
     X      Y
    -3.0  ,0.0
    0.0,   10.0
    3.0,   100.0
    This is a curve between force (Y) and defleciton (x) right, i am seeing this as per help file.
    Thank you
    OP
    Hi @George P Johnson
    Kindly let me know about this.
    Hi,
     X      Y
    -3.0  ,0.0
    0.0,   10.0
    3.0,   100.0
    Thank you
    Altair Employee
    Hi Gopal,
    This is Force vs Displacement curve.
    OP
    Hi Gopal,
    Hi,
    So is it -3 mm displacement at 0 kN force . Does not this look like any problem in this?
    If it is displacement with time, then at t=0, it under with pretension of 3 mm and then as time increase bolt loosens .This seems ok.
    Kindly clarify .
    Thank you
    Altair Employee
    Hi Gopal,
    This if Force vs Displacement only. For example purpose these values were used.
    Negative values in displacement indicate compression and positive shows tension. As per the curve when the spring is compressed 3mm no force is acting on it but when the spring is at its original state, ie 0, it has a force of 10N thereby making the spring pretensioned.
    OP
    Hi,
    Thank you for the update. In property spring 13, we have K_tens and then we have function ID for stiffness curve. If we have the curve, then we can have K_tension as blank right?
    Altair Employee
    Yes, you can leave it blank.
    OP
    Hi,
    I am working on a model having M16 bolt (having tightening torque of 250 Nm and thus pretension force of around 80 kN.I ahve used the following curve for bolt pretension assigned to type13 spring property.
    x         y
    -1.0  78000
    0.0   78000
    1.0   88000
    As the bolts is under pretension right from start, the energy error starts from -99 % and gradually reduces to -1 % to 4 %
    This is only happening when I am using pretension force of 14 kN and not exact value of 80 kN
    On using higher pretension force value, the energy error does not redcue from -99 % and the bolt made by 3D elements is getting deleted.
    Is this due to high pretension, force or anything else?
    I have send the files through secure link.
    Altair Employee
    Hi Gopal,
    This energy error seems to be because of the bolt pretension.
    We will check the model and will update you on this.
    OP
    Hi Gopal,
    Ignore the first file send.
    I have resend it again. Kindly consider the new one.
    Thank you.
    Altair Employee
    Hi Gopal,
    Reviewed your model.
    It seems like there is some high hourglass energy in the model. Please keep N=5 for shell elements and Isolid=24 for solid elements.
    There are many penetrations in the solver interface. Please correct them
    Finally, the model has high contact energy.
    Set “physical” contact interface gap value. Slightly increase the Gapmin value also. And use the recommended parameters for the interface and also check the master and slave material characteristics.
    OP
    Hi, the attached graphs are coming for me.
    For higher pretension force, the above said thing is happening.
    OP
    Hi,
    Please find the attached image . In this, there is penetration between two plates connected at nodes i.e no free edges in between. The penetration is coming due to large thickness value I think
    How can this be avoided here.
    Altair Employee
    Hi Gopal,
    Normally for pretension cases high negative energy error will be there during the starting of the run and it reduces gradually. But in this case for very high pretension forces high energy errors are coming, it reduces and finally it again goes up. It seems like it is due to this high force.
    The only possibility for the above case is to create connectors. You may have to delete one or two element layers of 12mm plate and use connectors for establishing the connection.
