1 - 7 of
71
sorry but I'm new in using the tool RapidMiner.
Sought by the operator must_contain not found. He really has this name?
I'm working with 150 000 examplosSet and has 40 attributes, and thought it might select for the FP-Growth seek rules with a particular attribute to be the consequent (or conclusion).
I still have the problem that when I use the Report Operator exceeds the limit of excel, so I can not even export rules.
Another problem I find is that when I use Weka's algorithms, such as W-FpGrowth never shows any results in the Result Overview.
Is there any tutorial that explains the integration of RapidMiner with weka?
already, thank you very much!
Hi,
please remember that you are using a software for free and getting free support. If you need guaranteed support with fast answering you should consider to get an Enterprise version of our software.
Regarding your question: must_contain is a parameter of the FP-Growth operator. If you cannot see it, you have to activate the expert mode by clicking the icon with the black man with hat on top of the parameter list.
Best regards,
Marius
Best regards,
Marius
Best regards,
Marius
