🎉Community Raffle - Win $25
Join and Win
[SOLVED] Nominal To Number Operator
macctenUser: "maccten"
New Altair Community Member
Updated by Jocelyn
Hi All
Im trying to massage data in order to run a clustering algorithm on it
The dataset I have has many nominal attributes and I wish to convert them to numbers in order that the clustering algorithm works correctly
I have used the nominal to number operator but am having problems with the dummy values replacing the nominal values with numbers
What I would like is something like below where each number actually represents a value
I am unable to get this working at present. Can anyone help me out…It’s a bit of a show stopper at present 
Old Value      Converted Value
CH              1
IE              2
CH              1
DE              3
IL              4
1 - 6 of 61
    You should use the Nominal to Numerical operator with coding_type set to dummy_coding.
    Best regards,
    Marius
    OP
    Hi Marius
    Thank you for the quick response
    This was originally what i was doing. I had a read Database operator which linked to a select attributes operator which selected a column that had only 3 available nominal values.
    I then connected up the Nominal To Numeric operator.
    What i was expecting was
    value    Converted Value
    Value_1          1
    Value_2          2
    Value_2          2
    What i got instead was
                Value_1 Value_2
    row 1      1            0
    row 2      0            1
    row 3      0            1
    This looks like more of what i would expect from a nominal to binomial operator
    Again thanks for your time
    It is a very frustrating problem
    Hello
    I reckon the coding type should be "unique integers" as in the following
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.3.008">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="generate_nominal_data" compatibility="5.3.008" expanded="true" height="60" name="Generate Nominal Data" width="90" x="112" y="75"/>
          <operator activated="true" class="nominal_to_numerical" compatibility="5.3.008" expanded="true" height="94" name="Nominal to Numerical" width="90" x="112" y="165">
            <parameter key="coding_type" value="unique integers"/>
            <list key="comparison_groups"/>
          </operator>
          <connect from_op="Generate Nominal Data" from_port="output" to_op="Nominal to Numerical" to_port="example set input"/>
          <connect from_op="Nominal to Numerical" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
    regards
    Andrew
    To get the result described above, the coding type must in fact be unique integers. BUT: for clustering that's usually not a good choice, since unique integers would imply an ordering of the values. But imagine you have the nominal values red, green and blue. If you assign red=1, green=2 and blue=3 it would imply that blue is three times as much as red, and that a "blue" instance is further away from a 'red' instance than from a 'green' instance. That's usually not desired.
    The dummy coding overcomes this and is the method of choice if you want to apply clustering, linear regression or any other algorithm that depends on only numerical values.
    Best regards,
    Marius
    Marius is absolutely correct of course.
    regards
    Andrew
    OP
    Hi Marius,
    What you say makes a lot of sense and it appears i was heading down this road which would have for sure given me a poor output from the model
    Thank you very much for your time
