[SOLVED] Name conflict detection when renaming multiple attributes
Is the following process supposed to throw an error? Prefixing all names with 'a' should not introduce any conflicts in the resulting name set, I would think.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.3.005">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="75">
<list key="attribute_values">
<parameter key="a" value="1"/>
<parameter key="aa" value="2"/>
</list>
<list key="set_additional_roles"/>
</operator>
<operator activated="true" class="rename_by_replacing" compatibility="5.3.005" expanded="true" height="76" name="Rename by Replacing" width="90" x="313" y="75">
<parameter key="replace_what" value="^"/>
<parameter key="replace_by" value="a"/>
</operator>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Rename by Replacing" to_port="example set input"/>
<connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>
Andrew
