[SOLVED] Generating Attributes for a specific date range
Dear Rapi-i Community,
I am working on a project where I need to generate an attribute for a specific date range. For example: Dates from 4/1/13 till 4/7/13 get a "week 1" attribute. Etc.
I was thinking about using the 'Generate Attribute' operation with a 'before date' command and an 'after date' command. But this seems very clunky and not replicateable over many iterations.
Do you have any advice to offer? ::)
Thank you very much.
Tim
Tim
1 - 4 of
41
You could generate a week number in the year using the generate attributes operator with the following functions.
Here's a process you could modify.
Hi,
It's got to do with where the week numbering system starts. Some systems start at "Week 0" and some start at "Week 1". It also depends on the day of the week that the week starts on (Sunday or Monday)...
It can get pretty confusing especially when you're working with different software....Excel, SQL ect ect...
Also, I'm not sure what RapidMiner regards as the first week of the year...Is week 53 of the old year also week 0 or 1 of the new year?
I work around for a lot of this stuff is using the year concatenated to the week "yyyyww"
