"SVM Models - Target Variable with more than two levels"
I have a data mining problem in which there are four levels in the target variable. I have used a SVM model in Statistica that works very well for my data - and supports the four level target variable. I am just starting out with Rapid Miner, and it looks like all the SVM models in Rapid Miner only support binary target variables. Is that the case? I think the libSVM implementation supports more than two levels (that is what Statistica uses) - but the description of this SVM implementation in Rapid Miner still seems to say that it only supports binary target variables. If this capability is not available now, is it planned for the future?
David
David
