[SOLVED] Find minimum value of column
Hello,
I have a simple scenario where I want to to apply a formula on generated attribute. I simplified the workflow to generate 10 samples and then generate attribute which will hold minimum value.
1 0.8633563476940593 2.467612009982549 2.467612009982549
2 0.06876328426040379 1.2924127751628518 1.2924127751628518
3 0.4846603438968893 -5.589923335093689 -5.589923335093689
4 0.9684928217146895 -6.350916620988873 -6.350916620988873
5 0.9366372796859641 1.2414027313347589 1.2414027313347589
6 0.692586106000668 -8.767780617998435 -8.767780617998435
7 0.40107538634598017 -5.189688812982061 -5.189688812982061
8 0.029369504278170422 -6.224623149327426 -6.224623149327426
9 0.07736300953569464 -7.153585749698594 -7.153585749698594
10 0.2802396559329807 -4.695913351021728 -4.695913351021728
Thanks
In the result below, the last colum is evaluated as min(att1). Why in last column is not displayed the minimum value?
<operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
<process expanded="true" height="411" width="762">
<operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75">
<parameter key="number_examples" value="10"/>
<parameter key="number_of_attributes" value="1"/>
</operator>
<operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="120">
<list key="function_descriptions">
<parameter key="Min" value="min(att1)"/>
</list>
</operator>
<connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
</process>
</operator>
Thanks
The generate attributes operator does an implicit loop over all the examples within an example set. The function sees the attribute value within the context of a "current example". The function finds the minimum of the attributes passed to it. This means the minimum of an attribute will always be the attribute itself for the current example if it is the only argument to the function.
I've attached a process that uses the Extract Macro operator that might do what you want. regards
Andrew
