Questions regarding Plot View
Hello,
I'm a Bachelor Student at the Technische Universität Darmstadt and I'm currently trying to use Rapidminer for my thesis.
I have a few questions/problems regarding the Plot View feature. I'm analyzing a CSV sheet of Poker stats which look like this:
I have a few problems in Plot View though:
1. There is no "export image..." Button on the left side when I'm on the scatter graph for example.
2. There is no legend for color if I select a color column (and there is no legend when I select "none" in the color column either)
3. The axes in the Scatter 3D Plot are really weird. For example if I take
VPIP -> x-Axis
PFR -> y-Axis
BB/100 -> z-Axis
All axes are between 0 and 2000 - this makes no sense at all for me. All my values are usually between 0 and 100 with the exception of BB/100 where it's in [-infty;+infty].
I've tried to use the scales settings but it does not work (it simply moves around the points: up or down, left or right etc depending on how I set them.)
Can anyone help me here?
Kind Regards
id_player hands Win% BB/100 vpip (w/walks) vpip pfr pfr (simple) vpip/pfr advThis is just a small extract. I've imported the sheet into a local repository and everything looks fine in the Data View.
9236 1211 0,21 0,00 21,93 20,48 19,98 18,66 1,10
31364 1031 0,23 0,00 36,11 34,92 11,35 10,96 3,18
43431 9747 0,17 -0,01 23,50 22,85 16,31 15,85 1,44
318 12770 0,18 -0,01 19,68 18,61 15,49 14,64 1,27
11351 7901 0,23 -0,02 26,44 24,95 23,26 21,95 1,14
56886 19753 0,16 -0,02 22,24 21,71 17,37 16,95 1,28
VPIP -> x-Axis
PFR -> y-Axis
BB/100 -> z-Axis
Kind Regards
1 - 1 of
11
1) You can export the current graph via the Export drop-down menu (I admit it is somewhat hidden..) button in the top-right corner of the Plot view.
2) Hm, I can't reproduce this here.. You could however resort to the Advanced Charts for your scatter plots (right next to the button for the Plot View), just drag&drop the x and y attributes onto the Domain dimension and Empty axis respectively.
3) Also not able to reproduce this without the data in question.
Regards,
Marco
