🎉Community Raffle - Win $25
Join and Win
[SOLVED] Join wordlists
User: "kasper2304"
New Altair Community Member
Updated by Jocelyn
Hi
Was reading a paper yesterday saying that some times it can be wise to do feature extraction separately on each class when doing text analysis. This I did by using two nodes for process documents from files, and then apply same setup on both, whereafter I merge the example sets. The results was very good...!
So now my problem is that I want to merge the two wordlists in order to apply the wordlist on the entire corpus, but I simply cannot figure out how to do it... Any suggestions?
Can see that the same question have been posted in another thread in January without any answer...
Best
Kasper
