Hi Master,
So i have a mixing drum which will contain 1kg of particles and a generated at 0.5 kg/s. So from 0 to 1 second the particle are generated then at 1 second the drum spin for 9rpm but when the simulation gets at 3.5 second the particle disappear and being generated again but at lesser number of particle. This behavior will repeat every 1.5 second. I tried to redo the simulation 4 times but the same is happening. So am I missing something. I followed this youtube video.
https://m.youtube.com/watch?v=DNVRnWILsoA&pp=ygULQWx0YWlyIEVERU0%3D
Thanks!
