🎉Community Raffle - Win $25
Join and Win
Reassigning class label
User: "DavidRaju"
New Altair Community Member
Updated by Jocelyn
could you please guide me, how can I proceed with the following
Class label(attribute) is discarded from the data set(containing 2000 tuples),the resulting data set without class label is  Dj.Performed some data mining operations(clustering) on Dj and divided the Dj in to sub groups Dj1, Dj2, Dj3. Now how can I reassign the class labels to the appropriate tuples which belongs to Dj1, Dj2 and Dj3.
Thanking you in anticipation.
1 - 2 of 21
    User: "Andrew2"
    Hello
    If the role of your class is set to label, the clustering operator will ignore it - so there is no need to delete it in the first place.
    Post your process if I've misunderstood.
    Andrew
    User: "DavidRaju"
    OP
    Thank you , i will try
