Altair RISE
Nominate Yourself Now!
create a bolt connection
User: "Patrick Straker"
Altair Community Member
Updated by Patrick Straker
when i use the fastener tool to create a bolt connection i get something like shown in the picture. but iam confused why the rb2's connect to every element along the hole. A nut and bolt connection presses on the top and the bottom the shank do not touch the inside of the hole. am i mistaken here ? did i do something wrong? is there a way to realize this ?
1 - 3 of 31
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    you might be looking for something like the other connector types.
    Take a look at the other options there, if they suit you better.
    OP
    this dosent work dosent tell me why just do nothing. in the pdf are only 2d exampels are there really no solution to simulate  bolt between 3d solids ??
    Altair Employee
    the picture i've sent before was obtained from the pdf, and it shows a 3D example, under 'threaded steped bolt'. Maybe it is not the exact one you're looking for.
    And the second picture i've sent was built using this exact connector type.
    You must be using some wrong parameters to create your connector, maybe. Can you double check the 'hole detection' parameters in your connector?
