Hanging on Image Miner
I have had a problem with RM which has basically forced me to abandon use. I am on Windows 7 and trying to open RM but the load hangs on loading the image miner extension. I have removed RM several times and re-installed. I loaded the newest version of JAVA (7) as recommended in one post I did find and still the program will not load. Is there a fix anyone knows about or a way to disable this extension so as to not cause the entire program to fail?
Thanks!
brian
RAPIDMINER_HOME is not set. Trying the directory 'C:\Program Files\Rapid-I\Rapid
Miner5\scripts\..'...
Using local jre: C:\Program Files\Rapid-I\RapidMiner5\scripts\..\jre\bin\java.ex
e...
Starting RapidMiner from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..' using
classes from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..\lib\rapidminer.ja
r'...
Jan 14, 2013 10:23:24 AM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: rapidminer.home is 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..'.
Jan 14, 2013 10:23:24 AM com.rapid_i.Launcher main
INFO: Launching RapidMiner, platform WIN64
Jan 14, 2013 10:23:24 AM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
Jan 14, 2013 10:23:24 AM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Exception in thread "main" java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.rapid_i.Launcher.main(Launcher.java:334)
Caused by: java.lang.UnsupportedClassVersionError: com/rapidminer/PluginInitPRul
es : Unsupported major.minor version 51.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$000(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at com.rapidminer.tools.plugin.PluginClassLoader.loadClass(PluginClassLo
ader.java:84)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at com.rapidminer.tools.plugin.Plugin.callInitMethod(Plugin.java:853)
at com.rapidminer.tools.plugin.Plugin.callPluginInitMethods(Plugin.java:
838)
at com.rapidminer.tools.plugin.Plugin.initPlugins(Plugin.java:819)
at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:948)
at com.rapidminer.RapidMiner.init(RapidMiner.java:505)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:218)
at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:523)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:505)
... 5 more
Thanks!
brian
e...
r'...
ader.java:84)
838)
... 5 more
1 - 5 of
51
Hello Brian,
try latest build http://www.sendspace.com/file/i798n0.
But it is for RM 5.3. I you can, try to download this version from SVN.
Best,
Václav
Best,
Václav
which version of RM and Image Plugin are you using?
Best,
Václav
