[Solved] Stemming for Indonesian language
andead13
andead13 New Altair Community Member
edited November 2024 in Community Q&A
I'm make indonesian news classification atm and stuck at stemming process
I found stemming for indonesian language written in java here
I'm trying to run the script using Execute Proses operator and having eror. How should i implement that script?
Answers
  • MariusHelf
    MariusHelf New Altair Community Member
    Hi,
    execute process is meant to execute other RapidMiner processes.
    The easiest way to integrate Java code into RapidMiner is to implement the new functionality as an operator in a custom extension. That requires knowledge of java programming and is described in our whitepaper How To Extend RapidMiner. It is freely available at http://rapid-i.com/content/view/306/233/lang,en/ .
    You can probably use one of the stemming operators from the text mining extension as a base.
    Best regards,
    Marius
  • andead13
    i see, i'll try by learning the document
    thx
Welcome!
Welcome!
