🎉Community Raffle - Win $25
Join and Win
[SOLVED ]java.net.SocketTimeoutException: Read timed out
User: "StaryVena"
New Altair Community Member
Updated by Jocelyn
Hello,
I have problem with access to remote repository with large files. When I try to list directory with 22 files (each file has about 200 MB) I get this error:
Exception: javax.xml.ws.WebServiceException
Message: java.net.SocketTimeoutException: Read timed out
Stack trace:
 com.sun.xml.internal.ws.transport.http.client.HttpClientTransport.readResponseCodeAndMessage(HttpClientTransport.java:196)
 com.sun.xml.internal.ws.transport.http.client.HttpTransportPipe.createResponsePacket(HttpTransportPipe.java:212)
 com.sun.xml.internal.ws.transport.http.client.HttpTransportPipe.process(HttpTransportPipe.java:203)
 com.sun.xml.internal.ws.transport.http.client.HttpTransportPipe.processRequest(HttpTransportPipe.java:122)
 com.sun.xml.internal.ws.transport.DeferredTransportPipe.processRequest(DeferredTransportPipe.java:95)
 com.sun.xml.internal.ws.api.pipe.Fiber.__doRun(Fiber.java:626)
 com.sun.xml.internal.ws.api.pipe.Fiber._doRun(Fiber.java:585)
 com.sun.xml.internal.ws.api.pipe.Fiber.doRun(Fiber.java:570)
 com.sun.xml.internal.ws.api.pipe.Fiber.runSync(Fiber.java:467)
 com.sun.xml.internal.ws.client.Stub.process(Stub.java:308)
 com.sun.xml.internal.ws.client.sei.SEIStub.doProcess(SEIStub.java:146)
 com.sun.xml.internal.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:98)
 com.sun.xml.internal.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:78)
 com.sun.xml.internal.ws.client.sei.SEIStub.invoke(SEIStub.java:129)
 $Proxy31.getFolderContents(Unknown Source)
 com.rapidminer.repository.remote.RemoteFolder.ensureLoaded(RemoteFolder.java:126)
 com.rapidminer.repository.remote.RemoteFolder.getSubfolders(RemoteFolder.java:157)
 com.rapidminer.repository.gui.RepositoryTreeModel$3.run(RepositoryTreeModel.java:258)
Cause
Exception: java.net.SocketTimeoutException
Message: Read timed out
Stack trace:
 java.net.SocketInputStream.socketRead0(Native Method)
 java.net.SocketInputStream.read(SocketInputStream.java:150)
 java.net.SocketInputStream.read(SocketInputStream.java:121)
 java.io.BufferedInputStream.fill(BufferedInputStream.java:235)
 java.io.BufferedInputStream.read1(BufferedInputStream.java:275)
 java.io.BufferedInputStream.read(BufferedInputStream.java:334)
 sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:633)
 sun.net.www.http.HttpClient.parseHTTP(HttpClient.java:579)
 sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1322)
 java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:468)
 com.sun.xml.internal.ws.transport.http.client.HttpClientTransport.readResponseCodeAndMessage(HttpClientTransport.java:192)
But folder with 22 images with size of 44 MB is OK.
My question is: where can I increase this read timeout?
Thank you.
Best,
Václav
1 - 3 of 31
    User: "Nils_Woehler"
    Hi Václav,
    you can set the timeout in the WebServiceTools in RapidMiner. In the current development version it is set to 20000.
    What would you suggest to set it to, especially with your folder with big files?
    Best,
    Nils
    User: "StaryVena"
    OP
    Hi Nils,
    it takes 64 seconds to resolve the file list of that folder. I don't think it is a good idea to set timeout to this value, because it is quite special case. But maybe you can put this value to the preferences.
    And thank you for help  ;)
    Best,
    Václav
    Hi Václav,
    thanks. We have added the connection timeout as a preferences parameter.
    Best,
    Nils
