🎉Community Raffle - Win $25
Join and Win
"Getting Results from Exampleset in Java"
User: "maxfax"
New Altair Community Member
Updated by Jocelyn
Hi,
I created a Process which calculates the Crossdistance between 1 single document and an Excelfile. The Process works fine and is properly executed in my Javaprogramm. Now i would like to get the Results or the Values of the 5 closest Documents to my Document out of the Exampleset. I understood that by the following code I can get the Examplesetresults. But how do i get the Values.
IOContainer ioResult = rm5.run();
ExampleSet resultSet = (ExampleSet) ioResult.getElementAt(1);
I attached a picture of which values i would like to get in my Program.
Thank you very much for you Help !
1 - 5 of 51
    User: "aborg"
    This might help: https://github.com/aborg0/rapidminer-integration-knime/blob/master/com.mind_era.knime_rapidminer.knime.nodes.local/src/com/mind_era/knime_rapidminer/knime/nodes/RapidMinerNodeModel.java#L273
    Just in case it will move along here is a copy of it:
    			for (Example example : result) {
    final DataRow row = example.getDataRow();
    ++i;
    if (i > result.size()) {
    break;
    final Function<Attribute, DataCell> transformFunction = new Function<Attribute, DataCell>() {
    @Override
    public DataCell apply(final Attribute a) {
    final double d = row.get(a);
    if (a.isNominal()) {
    return Double.isNaN(d) ? DataType.getMissingCell()
    : new StringCell(a.getMapping().mapIndex(
    (int) d));
    if (a.getValueType() == Ontology.INTEGER) {
    : new IntCell((int) d);
    if (a.getValueType() == Ontology.DATE) {
    return new DateAndTimeCell((long) d, true, false,
    false);
    if (a.getValueType() == Ontology.DATE_TIME) {
    final long utc = (long) d;
    final boolean hasDate = utc >= 24L * 3600 * 1000
    || utc < 0;
    return new DateAndTimeCell(utc, hasDate, !hasDate,
    !hasDate);
    if (a.getValueType() == Ontology.TIME) {
    return new DateAndTimeCell((long) d, false, true,
    true);
    if (a.isNumerical()) {
    return new DoubleCell(d);
    return DataType.getMissingCell();
    dataContainer.addRowToTable(new DefaultRow(attribsEntry
    .getValue() == null ? String.valueOf(i)
    : ((org.knime.core.data.StringValue) transformFunction
    .apply(attribsEntry.getValue()))
    .getStringValue(), Iterables.toArray(
    Iterables.transform(attribs, transformFunction),
    DataCell.class)));
    User: "maxfax"
    OP
    Thank you very much ! But is there really now easier way to read Data out of Examplesets ? I know that the values are going to be doubles and i also know the Names of the Attributes . But right know I dont really know how to declare the Attributes correctly,
    thank you very much
    User: "maxfax"
    OP
    So Basically what i am trying to get is a working method so i can store the data from the data view in the rapidminer gui into an integer value or string value in my java programm.
    I am sure there must be an easy way to do it since its an common idea to further use the results calculated with rapidminer.
    Thank you very much for your help ! :)
    User: "StaryVena"
    Hello maxfax,
    you can sort ExampleSet by operator "Sort" and that select only the first five by operator "Filter Example Range".
    You can get values in java this way:
    ExampleSet es = (ExampleSet) ioResult.getElementAt(1);
    Attributes ats = es.getAttributes();
    double[] dataRow = new double[ats.size()];
    for (Example example : es) {
    int i = 0;
    for (Attribute attribute : ats) {
    dataRow = example.getValue(attribute);
    i++;
    //TODO operation with one dataRow = example
    Best,
    Václav
    User: "maxfax"
    OP
    Thank you very much !!
    THis was exactly what I needed thx !! ;D
