🎉Community Raffle - Win $25
Join and Win
[SOLVED] Using date-values in context
mario_hofmannUser: "mario_hofmann"
New Altair Community Member
Updated by Jocelyn
Hello,
I ve got a question regarding the usage of dates in the context. I set a macro startdate e.g. as "2012-12-01" in a macro.
When I want to calculate the difference to a date in an example set I m not able to convert the variable in a valid time string. Using date_parse_custom(%{startdate},"yyyy-MM-dd","de") does not work and gives me only errors.
I created a workaround by setting multiple macros for each year, month and day and reset the current date. There I encountered the problem that the month adds 1 month to the current date. E.g. date_set(date_now(),"12",DATE_UNIT_MONTH) returns 2013-01-014.
Thanks for any advice!
Regards,
Mario
1 - 4 of 41
    Hi Mario,
    nice to see that you are actually using RapidMiner!
    Please remember that the macro is replaced *before* the actual evaluation of the expression. That means that you have to surround it with quotes in this case. Please have a look at the attached process for a working example.
    Best!
    Marius
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.3.000">
      <context>
        <input/>
        <output/>
        <macros>
          <macro>
            <key>date</key>
            <value>2012-01-28</value>
          </macro>
        </macros>
      </context>
      <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
        <process expanded="true" height="145" width="279">
          <operator activated="true" class="generate_data_user_specification" compatibility="5.3.000" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="30">
            <list key="attribute_values">
              <parameter key="date" value="date_parse_custom(&quot;%{date}&quot;, &quot;yyyy-MM-dd&quot;)"/>
            </list>
            <list key="set_additional_roles"/>
          </operator>
          <connect from_op="Generate Data by User Specification" from_port="output" to_port="result 1"/>
        </process>
      </operator>
    </process>
    Hi Mario,
    perhaps you only missed to quote the macro in
    I have attached an example process in which I used the date in the context to calculate the elapsed time between 2 dates.
    Please keep in mind that the results represents the time in ms and you have to convert it afterwards (e.g. by dividing it by 86 400 000 to get the time in days  ;) ).
    Hope that helps!
    Best,
    Edin
    <process version="5.2.008">
      <context>
        <input/>
        <output/>
        <macros>
          <macro>
            <key>startdate</key>
            <value>2012-12-01</value>
          </macro>
        </macros>
      </context>
      <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
        <process expanded="true" height="161" width="681">
          <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30">
              <parameter key="now" value="date_now()"/>
              <parameter key="startdate" value="date_parse_custom(&quot;%{startdate}&quot;,&quot;yyy-MM-dd&quot;)"/>
            </list>
          </operator>
          <operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="30">
            <list key="function_descriptions">
              <parameter key="diff_to_now" value="date_diff(startdate,now)"/>
              <parameter key="diff_in_days" value="date_diff(date_parse_custom(&quot;%{startdate}&quot;,&quot;yyyy-MM-dd&quot;),date_parse_custom(date_str_custom(date_now(),&quot;yyyy-MM-dd&quot;),&quot;yyyy-MM-dd&quot;))/86400000"/>
            </list>
          </operator>
          <connect from_op="Generate Data by User Specification" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
    One more remark: date_set() starts counting the months at 0, so January would be 0, February 1 etc. Additionally, the second argument should not be quoted.
    Yes, indeed I only missed the quotes.
    Thank you!
