I just installed the latest SVN version of Rapidminer Unuk. I was able to run it. But I am unable to access Help->Rapidminer Marketplace. I get the attached error when I try to.
the marketplace is not yet compatible with the latest svn version of RapidMiner. It will be updated only in the same moment as the next official RapidMiner version will be released.
To install extensions in the svn version, you can either check them out from svn, too, and build them manually, or you can go to the webinterface of the marketplace, download the extension and place them into the RapidMiner plugin directory: http://marketplace.rapid-i.com/
Best regards,
Marius
