🎉Community Raffle - Win $25
Join and Win
com.rapidminer.gui.OperatorDocToHtmlConverter.convert
daniel_thibaultUser: "daniel_thibault"
New Altair Community Member
Updated by Jocelyn
My extension documentation (for consumption by com.rapidminer.gui.OperatorDocumentationBrowser.assignDocumentation) keeps hitting a NullPointerException within com.rapidminer.gui.OperatorDocToHtmlConverter.convert when it calls trans.transform(xmlSource, new StreamResult(buffer)).  Now, this happens within java.xml.transform.Transformer so I'm not sure what exactly it's complaining about.
http://rapid-i.com/schemas/documentation/reference/1.0/documentation.xsd was useful to find out the grammar of the expected xml, which I'm following.
Trying to isolate the incorrect bit, I've cut down on the file until there only remains what follows below, but it still fails with a NullPointerException.  Any clue?
<p1:documents xmlns:p1="http://rapid-i.com/schemas/documentation/reference/1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
              xsi:schemaLocation="http://rapid-i.com/schemas/documentation/reference/1.0                http://rapid-i.com/schemas/documentation/reference/1.0/documentation.xsd";>
<operator key="operator.stream_trace" locale="en" version="5.2.008">
<title>Stream LTF Trace</title>
<synopsis>This operator can read a channel from an LTTng (Linux Trace Toolkit Next Generation) trace written in LTF 2.6 by incrementally caching it.</synopsis>
</operator>
</p1:documents>
1 - 4 of 41
    Hi,
    can you please provide a stacktrace? Where did you put your XML file?
    Best,
    Nils
    No stack trace, the exception is issued from within javax.xml.transform.Transformer. Within the plugin jar, the xml file is at LTFDataReader/import/data/stream_trace.xml; in the project it lies at resources/LTFDataReader/import/data/stream_trace.xml.  The file is found and the stream created; the exception occurs at com.arpidminer.gui.OperatorDocToHtmlConverter.convert(), line 97: "Transformer trans = transFact.newTransformer(xsltSource);".  The stack shown in Eclipse is:
    Daemon Thread [ProgressThread] (Suspended)
    ArrayList<E>.indexOf(Object) line: not available
    ArrayList<E>.contains(Object) line: not available
    XIncludeAwareParserConfiguration(XML11Configuration).addCommonComponent(XMLComponent) line: not available
    XIncludeAwareParserConfiguration(XML11Configuration).<init>(SymbolTable, XMLGrammarPool, XMLComponentManager) line: not available
    XIncludeAwareParserConfiguration.<init>(SymbolTable, XMLGrammarPool, XMLComponentManager) line: not available
    XIncludeAwareParserConfiguration.<init>() line: not available
    SAXParserImpl$JAXPSAXParser(SAXParser).<init>(SymbolTable, XMLGrammarPool) line: not available
    SAXParserImpl$JAXPSAXParser(SAXParser).<init>() line: not available
    SAXParserImpl$JAXPSAXParser.<init>(SAXParserImpl) line: not available
    SAXParserImpl.<init>(SAXParserFactoryImpl, Hashtable, boolean) line: not available
    SAXParserImpl.<init>(SAXParserFactoryImpl, Hashtable) line: not available
    SAXParserFactoryImpl.newSAXParserImpl() line: not available
    SAXParserFactoryImpl.setFeature(String, boolean) line: not available
    Parser.parse(InputSource) line: not available
    XSLTC.compile(InputSource, String) line: not available
    XSLTC.compile(String, InputSource, int) line: not available
    TransformerFactoryImpl.newTemplates(Source) line: not available
    TransformerFactoryImpl.newTransformer(Source) line: not available
    OperatorDocToHtmlConverter.convert(InputStream, Operator) line: 97
    OperatorDocumentationBrowser.parseXmlAndReturnHtml(InputStream) line: 190
    OperatorDocumentationBrowser.access$1(OperatorDocumentationBrowser, InputStream) line: 188
    OperatorDocumentationBrowser$1.run() line: 313
    ProgressThread$2.run() line: 189
    Executors$RunnableAdapter<T>.call() line: not available
    FutureTask$Sync.innerRun() line: not available
    FutureTask<V>.run() line: not available
    ThreadPoolExecutor.runWorker(ThreadPoolExecutor$Worker) line: not available
    ThreadPoolExecutor$Worker.run() line: not available
    Thread.run() line: not available
    The only console output from javax.xml.tansform is ERROR:  ''.  The exception is a TransformerException with a cause of NullPointerException.  I guess I'll see if I can't convince Eclipse to run this in a 1.6 jdk so I can follow the trace deeper in.
    All right, trans.transform(xmlSource, new StreamResult(buffer)); takes us to:
    com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl
        public void transform(Source source, Result result)                          313
            throws TransformerException
            if (!_isIdentity) {
                if (_translet == null) {
                    ErrorMsg err = new ErrorMsg(ErrorMsg.JAXP_NO_TRANSLET_ERR);      318
                    throw new TransformerException(err.toString());
                // Pass output properties to the translet
                transferOutputProperties(_translet);                                322
            final SerializationHandler toHandler = getOutputHandler(result);        325
            if (toHandler == null) {
                ErrorMsg err = new ErrorMsg(ErrorMsg.JAXP_NO_HANDLER_ERR);          327
                throw new TransformerException(err.toString());                      328
            if (_uriResolver != null && !_isIdentity) {                              331
                _translet.setDOMCache(this);                                        332
            // Pass output properties to handler if identity
            if (_isIdentity) {                                                      336
                transferOutputProperties(toHandler);                                337
            transform(source, toHandler, _encoding);                                340
            try{
                if (result instanceof DOMResult) {                                  342
                    ((DOMResult)result).setNode(_tohFactory.getNode());              343
                } else if (result instanceof StAXResult) {                          344
                      if (((StAXResult) result).getXMLEventWriter() != null)        345
                        (_tohFactory.getXMLEventWriter()).flush();                  347
                    else if (((StAXResult) result).getXMLStreamWriter() != null) {  349
                        (_tohFactory.getXMLStreamWriter()).flush();                  350
                        //result = new StAXResult(_tohFactory.getXMLStreamWriter()); 351
            } catch (Exception e) {                                                  354
                System.out.println("Result writing error");                          355
    We reach 322, then 325, then 340.
        private void transform(Source source, SerializationHandler handler,          696
            String encoding) throws TransformerException
            try {
                * According to JAXP1.2, new SAXSource()/StreamSource()
                * should create an empty input tree, with a default root node.
                * new DOMSource()creates an empty document using DocumentBuilder.
                * newDocument(); Use DocumentBuilder.newDocument() for all 3
                * situations, since there is no clear spec. how to create
                * an empty tree when both SAXSource() and StreamSource() are used.
                if ((source instanceof StreamSource && source.getSystemId()==null    708
                    && ((StreamSource)source).getInputStream()==null &&
                    ((StreamSource)source).getReader()==null)||
                    (source instanceof SAXSource &&
                    ((SAXSource)source).getInputSource()==null &&
                    ((SAXSource)source).getXMLReader()==null )||
                    (source instanceof DOMSource &&
                    ((DOMSource)source).getNode()==null)){
                            DocumentBuilderFactory builderF = FactoryImpl.getDOMFactory(_useServicesMechanism);
                            DocumentBuilder builder = builderF.newDocumentBuilder(); 717
                            String systemID = source.getSystemId();
                            source = new DOMSource(builder.newDocument());          719
                            // Copy system ID from original, empty Source to new
                            if (systemID != null) {                                  722
                              source.setSystemId(systemID);
                if (_isIdentity) {                                                  726
                    transformIdentity(source, handler);
                } else {
                    _translet.transform(getDOM(source), handler);                    729
            } catch (TransletException e) {
                if (_errorListener != null) postErrorToListener(e.getMessage());    732
                throw new TransformerException(e);
            } catch (RuntimeException e) {
                if (_errorListener != null) postErrorToListener(e.getMessage());    735
                if (_errorListener != null) postErrorToListener(e.getMessage());    738
            } finally {
                _dtmManager = null;                                                  741
            // If we create an output stream for the Result, we need to close it after the transformation.
            if (_ostream != null) {                                                  745
                try {
                    _ostream.close();                                                747
                catch (IOException e) {}
                _ostream = null;                                                    750
    The 708 if fails (is skipped) and so does 726 so we next reach 729.  At this point source and handler are defined (not null).  But this is where an exception is thrown, so we end up at 735 and the rest is as you'd expect.
    At 729, the getDOM(source) succeeds.  Then we jump to:
    package com.sun.org.apache.xalan.internal.xsltc.runtime.AbstractTranslet.transform
            try {
                transform(document, document.getIterator(), handler);                611
            } finally {
                _keyIndexes = null;
    It is apparently the Iterator that fails after a few calls of hasNext; I can't tell exactly where or why because the intermediate GregorSamsa.transform(DOM, DTMAxisIterator, SerializationHandler) call has a "line not available" in Eclipse's stack display.
    If the Iterator over the XML file fails I assume your XML file is somehow malformed.
    Here you have the example code of the new documentation of write weights operator
    <?xml-stylesheet type="text/xsl" href="../../../../documentation2html.xsl"?>
    <!-- each operator should have a key that consists of "operator." plus the operator's key. -->
    <operator key="operator.write_weights" locale="en" version="5.2.003">
    <title>Write Weights</title>
    <synopsis>This operator writes the given attribute weights into the specified file.</synopsis>
    <text>
    <paragraph>The Write Weights operator writes the attribute weights provided at the input port into the specified file. The path of the file is specified through the <em>attribute weights file</em> parameter. Each line in the file holds the name of one attribute and its weight. The <reference key="operator.read_weights">Read Weights</reference> operator can be used to read the weights written by this operator. </paragraph>
    <paragraph>The attribute weights specify the relevance of the attributes with respect to the label attribute. There are numerous operators that create attribute weights e.g. the Weight by Correlation, Weight by PCA etc. Operators that generate attribute weights are located at &apos;Modeling/Attribute Weighting&apos; in the Operators Window.</paragraph>
    </text>
    <differentiation>
    <relatedDocument key=""></relatedDocument>
    </differentiation>
    <inputPorts>
    <port name="input" type="com.rapidminer.example.AttributeWeights">This input port expects attribute weights. It is the output of the Weight by Correlation operator in the attached Example Process.</port>
    </inputPorts>
    <outputPorts>
    <port name="through" type="com.rapidminer.example.AttributeWeights">The attribute weights that were provided at the input port are delivered through this output port without any modifications.This is usually used to reuse the same attribute weights in further operators of the process.</port>
    </outputPorts>
    <parameters>
    <!-- description of the parameters and the corresponding values -->
    <parameter key="attribute_weights_file" type="filename">The path of the file where the attribute weights are to be written is specified here. It can be selected using the <em>choose a file</em> button.</parameter>
    <parameter key="encoding" type="selection">This is an expert parameter. There are different options, users can choose any of them</parameter>
    </parameters>
    <relatedDocuments>
    </relatedDocuments>
    <tutorialProcesses>
    <tutorialProcess key="process.write_weights.write_read_weights" title="Writing and then Reading attribute weights from a file">
    <description>
    <paragraph>This Example Process shows how the Write Weights operator can be used for writing attribute weights and how the Read Weights operator can be used for reading attribute weights from this file . The &apos;Sonar&apos; data set is loaded using the Retrieve operator. The Weight by Correlation operator is applied on it. A <em>breakpoint</em> is inserted here so that you can have a look at the attribute weights. The resultant weights are provided as input to the Write Weights operator. The <em>attribute weights file</em> parameter is set to &apos;D:\sonar weights&apos; thus a file named &apos;sonar weights&apos; is created (if it does not already exist) in the &apos;D&apos; drive of your computer. You can open the written weights file and make changes in it (if required). The attribute weights file is then read by using the Read Weights operator. The <em>attribute weights file</em> parameter is set to &apos;D:\sonar weights&apos; to read the same file that was written by the Write Weights operator. The resultant weights are connected to the <em>result</em> port of the process. The attribute weights can be seen in the Results Workspace.</paragraph>
    <!-- tutorialProcess description: What is done and shown here? You can use formated text here -->
    </description>
    <process version="5.2.003">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process">
        <process expanded="true" height="398" width="625">
          <operator activated="true" class="retrieve" compatibility="5.2.003" expanded="true" height="60" name="Sonar" width="90" x="112" y="75">
            <parameter key="repository_entry" value="//Samples/data/Sonar"/>
          </operator>
          <operator activated="true" breakpoints="after" class="weight_by_correlation" compatibility="5.2.003" expanded="true" height="76" name="Weight by Correlation" width="90" x="246" y="75"/>
          <operator activated="true" class="write_weights" compatibility="5.2.003" expanded="true" height="60" name="Write Weights" width="90" x="380" y="75">
            <parameter key="attribute_weights_file" value="D:\sonar weights.txt"/>
          </operator>
          <operator activated="true" class="read_weights" compatibility="5.2.003" expanded="true" height="60" name="Read Weights" width="90" x="380" y="210">
          </operator>
          <connect from_op="Sonar" from_port="output" to_op="Weight by Correlation" to_port="example set"/>
          <connect from_op="Weight by Correlation" from_port="weights" to_op="Write Weights" to_port="input"/>
          <connect from_op="Read Weights" from_port="output" to_port="result 1"/>
          <portSpacing port="sink_result 1" spacing="180"/>
          <portSpacing port="sink_result 2" spacing="90"/>
        </process>
      </operator>
    </process>
    </tutorialProcess>
    </tutorialProcesses>
    </operator>
    </p1:documents>
    Best,
    Nils
