Process Document output
Hi,
I am trying to get top 10 words based on there occurrence from the output of process document .But when I use generate attribute to apply some macors ;I can connect only examples of process document to generate attribute but not the word. Is there any other way to get only top 10 words along with count of there occurrence.
Any help will be appreciated.
Regard,
Ankit
Regard,
Ankit
1 - 3 of
31
if you want to process the word vector, you have to use the Wordvector to Data operator.
Best regards,
Marius
