can't start with rapidnet
Hi everybody,
I downloaded and installed Rapidnet. I can see the "community" example but I can't use the tool. I have some questions:
1) Where can I find English documentation ?
2) How do I connect RapidNet to a database? And, can I use PostgreSQL db?
3) I understand that to use Rapidnet I must first create a RapidMiner flow, is that right? Do I have to use a particular RapidMiner plugin?
Thanks in advance
regards,
ticemba
Thanks in advance
regards,
ticemba
RapidNet as you can download it from the our website is more a demo instance than a full version of this product. It is basically a client which connects to a RapidNet server to fetch the data to display it as a network for demonstration. Since RapidNet is not an open source product we do not provide any public documentation and the only way to reconfigure it is via the configuration.xml file described in this posting. If you are interested in this product, feel free to contact us (see www.rapid-i.com).
Best regards
Marcin
