🎉Community Raffle - Win $25
Join and Win
Generating reports in a loop doesn't seem to work for some reason.
User: "tennenrishin"
New Altair Community Member
Updated by Jocelyn
In the process below, the report's image files are generated, but not the html file. Did I miss out something?
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.2.008">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
   <process expanded="true" height="659" width="1047">
     <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="179" y="120">
       <list key="attribute_values">
         <parameter key="a" value="1"/>
       </list>
       <list key="set_additional_roles"/>
     </operator>
     <operator activated="true" class="loop_examples" compatibility="5.2.008" expanded="true" height="76" name="Loop Examples" width="90" x="313" y="120">
         <operator activated="true" class="reporting:generate_report" compatibility="5.2.000" expanded="true" height="76" name="Generate Report" width="90" x="112" y="30">
           <parameter key="report_name" value="Report %{example}"/>
           <parameter key="format" value="HTML"/>
           <parameter key="html_output_directory" value="./my documents/report%{example}"/>
         </operator>
         <operator activated="true" class="reporting:add_text" compatibility="5.2.000" expanded="true" height="76" name="Add Text" width="90" x="246" y="30">
           <parameter key="report_text" value="hello world"/>
         </operator>
         <operator activated="true" class="reporting:report" compatibility="5.2.000" expanded="true" height="60" name="Report" width="90" x="380" y="30">
           <parameter key="specified" value="true"/>
           <parameter key="reportable_type" value="Data Table"/>
           <parameter key="renderer_name" value="Plot View"/>
           <list key="parameters">
             <parameter key="plotter" value="Scatter"/>
             <parameter key="scatter_axis_x_axis" value="a"/>
             <parameter key="scatter_axis_x_axis_log_scale" value="false"/>
             <parameter key="scatter_axis_y_axis" value="a"/>
             <parameter key="scatter_axis_y_axis_log_scale" value="false"/>
             <parameter key="scatter_plot_column" value="a"/>
             <parameter key="scatter_jitter_amount" value="0"/>
             <parameter key="scatter_rotate_labels" value="false"/>
             <parameter key="scatter_multiple_axis_x_axis_log_scale" value="false"/>
             <parameter key="scatter_multiple_jitter_amount" value="0"/>
             <parameter key="scatter_multiple_rotate_labels" value="false"/>
             <parameter key="scatter_matrix_jitter_amount" value="0"/>
             <parameter key="bubble_axis_x_axis_log_scale" value="false"/>
             <parameter key="bubble_axis_y_axis_log_scale" value="false"/>
             <parameter key="bubble_rotate_labels" value="false"/>
             <parameter key="parallel_rotate_labels" value="false"/>
             <parameter key="parallel_local_normalization" value="false"/>
             <parameter key="deviation_rotate_labels" value="false"/>
             <parameter key="deviation_local_normalization" value="false"/>
             <parameter key="series_rotate_labels" value="false"/>
             <parameter key="series_multiple_rotate_labels" value="false"/>
             <parameter key="som_jitter_amount" value="0"/>
             <parameter key="block_axis_x_axis_log_scale" value="false"/>
             <parameter key="block_axis_y_axis_log_scale" value="false"/>
             <parameter key="block_jitter_amount" value="0"/>
             <parameter key="block_rotate_labels" value="false"/>
             <parameter key="pie_absolute_values" value="false"/>
             <parameter key="pie_aggregation" value="none"/>
             <parameter key="pie_use_distinct" value="false"/>
             <parameter key="pie_explosion_amount" value="0"/>
             <parameter key="pie_3d_absolute_values" value="false"/>
             <parameter key="pie_3d_aggregation" value="none"/>
             <parameter key="pie_3d_use_distinct" value="false"/>
             <parameter key="ring_absolute_values" value="false"/>
             <parameter key="ring_aggregation" value="none"/>
             <parameter key="ring_use_distinct" value="false"/>
             <parameter key="ring_explosion_amount" value="0"/>
             <parameter key="bars_absolute_values" value="false"/>
             <parameter key="bars_rotate_labels" value="false"/>
             <parameter key="bars_aggregation" value="none"/>
             <parameter key="bars_use_distinct" value="false"/>
             <parameter key="bars_orientation" value="vertical"/>
             <parameter key="bars_stacked_absolute_values" value="false"/>
             <parameter key="bars_stacked_rotate_labels" value="false"/>
             <parameter key="bars_stacked_aggregation" value="none"/>
             <parameter key="bars_stacked_use_distinct" value="false"/>
             <parameter key="bars_stacked_orientation" value="vertical"/>
             <parameter key="pareto_rotate_labels" value="false"/>
             <parameter key="pareto_sorting_direction" value="Descending Keys"/>
             <parameter key="pareto_show_bar_labels" value="true"/>
             <parameter key="pareto_show_cumulative_labels" value="false"/>
             <parameter key="distribution_rotate_labels" value="false"/>
             <parameter key="histogram_absolute_values" value="false"/>
             <parameter key="histogram_rotate_labels" value="false"/>
             <parameter key="histogram_log_scale" value="false"/>
             <parameter key="histogram_number_of_bins" value="40"/>
             <parameter key="histogram_opaqueness" value="100"/>
             <parameter key="histogram_color_absolute_values" value="false"/>
             <parameter key="histogram_color_rotate_labels" value="false"/>
             <parameter key="histogram_color_log_scale" value="false"/>
             <parameter key="histogram_color_number_of_bins" value="40"/>
             <parameter key="histogram_color_opaqueness" value="100"/>
           </list>
         </operator>
         <connect from_port="example set" to_op="Generate Report" to_port="through 1"/>
         <connect from_op="Generate Report" from_port="through 1" to_op="Add Text" to_port="through 1"/>
         <connect from_op="Add Text" from_port="through 1" to_op="Report" to_port="reportable in"/>
         <connect from_op="Report" from_port="reportable out" to_port="example set"/>
         <portSpacing port="source_example set" spacing="0"/>
         <portSpacing port="sink_example set" spacing="0"/>
         <portSpacing port="sink_output 1" spacing="0"/>
       </process>
     </operator>
     <connect from_op="Generate Data by User Specification" from_port="output" to_op="Loop Examples" to_port="example set"/>
   </process>
 </operator>
</process>
Platform: WIN7
