"Insert and Update a Database"
Hi all,
Forgive me if this is a simple question. I am reading data from a csv file which matches a database table. The primary key of the db is composed of several fields. So far I have not had to much luck with inserting or updating because I get primary key violations. When you setup the file can you setup multiple id's that Match the db?
