Neural Network Toplogy
1 - 8 of
81
I read in an old post (2011) that this was on the to-do list, has it been implemented yet?
No, not yet, and to be honest it does not have high priority for us. There are a number of algorithms that we prefer a lot over the Neural Networks - SVMs for instance deliver comparable results, but are way easier to configure and to optimize and at the same time have a smaller tendency to overfit.
However, to change at least the size of a fixed number of hidden Layers, you can create Set Macro operators inside the Loop Parameters operator, iterate the macro values and use the macros to define the sizes of the layers.
Best, Marius
Best, Marius
Hi Marius,
Best, Marius
I used Loop Parameters operator and Set Macro operator to chane size of the layers, but I get the error: "operator cannot be executed (For input string: "ilk")" "ilk" is the macro name.
<operator activated="true" class="neural_net" compatibility="6.4.000" expanded="true" height="76" name="Neural Net" width="90" x="112" y="30">
<list key="hidden_layers">
<parameter key="hiddenlayer" value="%{ilk}"/>
</list>
</operator>
Have you tried pinging @yasinkaya?
1 - 1 of
11
Hi Marius,
Best, Marius
</list>
</operator>
