"Aggregate Attribute with 0 matching attributes asks for a bug report"
The following minimalistic process, when run, throws an error box with a "Send Bug Report" button.
I don't have bugtracker login credentials, so here it is:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="641" width="1013">
<operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="empty" width="90" x="112" y="75">
<list key="attribute_values"/>
<list key="set_additional_roles"/>
</operator>
<operator activated="true" class="generate_aggregation" compatibility="5.2.008" expanded="true" height="76" name="max_f_" width="90" x="313" y="75">
<parameter key="attribute_name" value="max_f_"/>
<parameter key="attribute_filter_type" value="regular_expression"/>
<parameter key="regular_expression" value="f_.*"/>
<parameter key="aggregation_function" value="maximum"/>
</operator>
<connect from_op="empty" from_port="output" to_op="max_f_" to_port="example set input"/>
<connect from_op="max_f_" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>
1 - 1 of
11
will be fixed in the next release.
Regards,
Marco
