Generate Attributes has unexpected behavior with zero examples (or not?)
In the example below, the expressions in the Generate Attributes operator have errors, but RM gives no error/warning message if the number of examples in the ExampleSet happens to be 0. Is this intended?
Isak
<?xml version="1.0" encoding="UTF-8" standalone="no"?>Thanks,
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="659" width="1059">
<operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="108" y="30">
<list key="attribute_values">
<parameter key="a" value="1"/>
</list>
<list key="set_additional_roles"/>
</operator>
<operator activated="true" class="filter_examples" compatibility="5.2.008" expanded="true" height="76" name="Filter Examples" width="90" x="246" y="30">
<parameter key="invert_filter" value="true"/>
</operator>
<operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="30">
<list key="function_descriptions">
<parameter key="b" value="nonExistantAttribute+1"/>
<parameter key="c" value="))()(A<<$>++"/>
</list>
</operator>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>
Isak
Example:
