1 - 6 of
61
I too am interested in knowing this but in my case how to configure the reporting extensions to use an advanced graph if it is even possible?
You can use the Reporting extension to export pdf or Excel files with your plots:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
<process expanded="true" height="405" width="570">
<operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30">
<parameter key="target_function" value="checkerboard classification"/>
<parameter key="number_of_attributes" value="2"/>
</operator>
<operator activated="true" class="principal_component_analysis" compatibility="5.3.000" expanded="true" height="94" name="PCA" width="90" x="180" y="30"/>
<operator activated="true" class="reporting:generate_report" compatibility="5.2.001" expanded="true" height="76" name="Generate Report" width="90" x="315" y="30">
<parameter key="report_name" value="test"/>
<parameter key="format" value="Excel"/>
<parameter key="pdf_output_file" value="C:\Users\mhelf\Desktop\test.pdf"/>
<parameter key="excel_output_file" value="C:\Users\mhelf\Desktop\test.xls"/>
</operator>
<operator activated="true" class="reporting:report" compatibility="5.2.001" expanded="true" height="60" name="Report" width="90" x="450" y="30">
<parameter key="specified" value="true"/>
<parameter key="reportable_type" value="PCA Model"/>
<parameter key="renderer_name" value="Cumulative Variance Plot"/>
<list key="parameters"/>
</operator>
<connect from_op="Generate Data" from_port="output" to_op="PCA" to_port="example set input"/>
<connect from_op="PCA" from_port="preprocessing model" to_op="Generate Report" to_port="through 1"/>
<connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/>
<connect from_op="Report" from_port="reportable out" to_port="result 1"/>
</process>
</operator>
</process>
In the reporting set create a Report, then add an element to the report after the data set processing. Within the parameters under data set there is charts and you can configure though and export those to the pdf. My problem was I saw an option in the reporting to add advanced charts but I couldn't get it configured to actually output an advanced chart. So i was curious if this was possible or will be availble in the next update of RM and the reporting extention?
