<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="405" width="570"> <operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="checkerboard classification"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="principal_component_analysis" compatibility="5.3.000" expanded="true" height="94" name="PCA" width="90" x="180" y="30"/> <operator activated="true" class="reporting:generate_report" compatibility="5.2.001" expanded="true" height="76" name="Generate Report" width="90" x="315" y="30"> <parameter key="report_name" value="test"/> <parameter key="format" value="Excel"/> <parameter key="pdf_output_file" value="C:\Users\mhelf\Desktop\test.pdf"/> <parameter key="excel_output_file" value="C:\Users\mhelf\Desktop\test.xls"/> </operator> <operator activated="true" class="reporting:report" compatibility="5.2.001" expanded="true" height="60" name="Report" width="90" x="450" y="30"> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="PCA Model"/> <parameter key="renderer_name" value="Cumulative Variance Plot"/> <list key="parameters"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="PCA" to_port="example set input"/> <connect from_op="PCA" from_port="preprocessing model" to_op="Generate Report" to_port="through 1"/> <connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/> <connect from_op="Report" from_port="reportable out" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
