Build
Hi, I am struggling with building rapinet from svn.
The build path appears to be missing 2 dependent projects
RapidNetAPI_shelob
RapidNetDBSource_shelob
Judging from these and the code is it out of date and if so will sourceforge be updated with the latest code?
Thanks in advance
RapidNetAPI_shelob
Thanks in advance
1 - 2 of
21
we are investigating the problem. From where exactly did you download the source code? Do you want to change the code? Otherwise, you could try the binary windows installers available on sourceforge.
Best,
Marius
