🎉Community Raffle - Win $25
Join and Win
[SOLVED]The prediction score are different between the Rapidminer and Libsvm
User: "winecoding"
New Altair Community Member
Updated by Jocelyn
I ran the SVM classification using both Rapidminer and Libsvm against the same data set. In the rapidminer, I also used the libsvm implementation. The document processing scheme and svm parameter setting are exactly the same for both experiment. However, the generated score are different. Are there any possible reasons to cause this kind of different?
