apriori algorithm
User: "shruti"
New Altair Community Member
Updated by Jocelyn
include apriori in rapid miner and how to compare assosiation rules for intrusion detection.
1 - 11 of 111
    User: "Skirzynski"
    You can use "FP-Growth" + "Create Association Rules" instead of Apriori.
    User: "shruti"
    OP
    Thanks
      how to compare those assosiation rules(training and tested data) generated for intrusion detection.
    Regards
    shruti
    User: "Skirzynski"
    I don't know what do you mean with "compare for intrusion detection", but there is a "Apply Association Rules" operator which can be helpful for you.
    User: "shruti"
    OP
    i want to know how to compare assosiation rules generated for training and testing data.
    regards
    shruti
    User: "usct01"
    Hi
    Is there any documentation describing the process operators in detail, like algorithm used, source code, variation example etc.
    I know each process operator shows some details in wiki links but that seems inadequate.
    I am interested in Text Mining and decision trees specifically
    Thanks
    Deepak
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    you can expect vastly improved operator documentation soon™ ;)
    If you need even more information, I'm afraid you will need to check the source code of the operators themselves.
    Regards,
    Marco
    User: "shruti"
    OP
    Hi,
    how to check the source code of operators themselves and how the new operators are created.
      shruti
    User: "Skirzynski"
    On our Sourceforge site you can checkout the source code of RapidMiner (current version is Unuk) and several extensions/plugins via subversion. To learn how to create new operators you can study the source code (escpecially the packages com.rapidminer.operator.*) or buy our "How to Extend RapidMiner 5.0" white paper.
    User: "yahya_ardi88"
    Sorry, i am newbie for rapidminer. I want study from all of you.
    I want use rapidminer for my research about association (market business analysis), actually apriori algorithm.
    1. what's the difference between W-Apriori and FP-Growth + Create Asspciation Rule? Where the easiest for studied?
    2. Have you tutorial (video/ articles about Market Business Analysis using Apriori Algorithm in Rapidminer)?
    User: "haddock"
    Hi there,
    In answer to question 1:
    There is no difference in the output of the FPGrowth algorithm and the a Priori algorithm, both produce the same frequent item sets from the same inputs. Both are moronically simple to understand, see wikipedia for details.
    In answer to question 2:
    No.
    Best wishes
    H
    haddock wrote:
    Hi there,
    No.
    Best wishes
    H
    Thanks for the answer.
