[SOLVED] regex and string-parsing question
New Altair Community Member
Updated by Jocelyn
I hope my question comes across okay.
Suppose...
We have macros %{A} and %{P}. Where...
%{P} contains some token (say #1) which serves as a kind of place-holder/wildcard.
%{A} is some unknown string, but it matches %{P} in the sense that if we replace #1 in %{P} with some known regex (say .*) then the result matches %{A}
Question:
Is there a way to obtain that part (substring) of %{A} that matches the .* that replaced #1 in %{P}?
In other words is there a way to determine what #1 represented in %{A}?
Simplistic examples:
%{A}=abcd
%{P}=a#1d
Required output: bc
%{A}=abcde
%{P}=ab#1
Required output: cde
Further comments:
I've read up a bit on "capturing groups" in regular expressions but I can't figure out a way to access what is captured by a group and put it into another macro.
Suppose...
Question:
%{A}=abcd
%{P}=a#1d
Required output: bc
%{A}=abcde
%{P}=ab#1
Further comments:
1 - 2 of
21
I have no idea why you want to do it with macros, but everything is possible with RapidMiner
Best, Marius
