SOLVED - Installing Extenstion onto RapidAnalytics
I see 'Read Database' Operator under 'Operator and Extensions'.
But when I use that operator in process and run remotely I get the following error
"com.rapidminer.operator.UserError: The dummy operator Generate Report (replacing reporting:generate_report) cannot be executed."
which according to other threads 'extension jar is not available' on the server.
'Report Database' operator is shown under operator on the server not under 'Extensions'.
If I change the 'com.rapidanalytics.plugindir' under 'System Settings' to ../rapidAnalytics/plugins' directory after copying the jar file for 'Reporting' extension,
all the opertors disapper and 'Reporting' extension is shown under 'Extension' in red.
How do I fix this ?
How do I fix this ?
