"Scatter Multiple: How to Select Multiple Dimensions?"
Hi,
I tried to select multiple dimensions by holding CTRL Key while clicking on the attributes from the list as described in The RapidMiner Plotters 2: Scatter Multiple by Ingo Mierswa but this did not work! I have 60 attributes and I can select any one of them from the list! When clicking with or without holding the CTRL Key the selection of the attribute is not maintained... Is there another way to do it?
1 - 4 of
41
Yes I did select an attribute (I set a label and then an attribute on the x-Axis) the problem is always the same: it is impossible to select an attribute from the y-list. I tried with or without holding the CTRL key, by dragging the item to the graph, by double-clicking on it, by clicking first, holding the CTRL key first and I even tried the ALT key and the SHIFT key. None worked!
did you set the x-Axis attribute? Without an attribute on the x-Axis you plot will stay empty.
Best,
Nils
