naive bayes classification - confidences are binary
I'm using Naive Bayes to develop a model and then applying that model to classify a set of new documents into relevant and not. When I do this, all of the classification confidences are binary, matching the predicted group. If I switch out Naive Bayes for k-NN, I do get non-binary confidences. Are these binary confidences correct (seems unlikely) or is something going wrong?
Thanks in advance.
Thanks in advance.
1 - 5 of
51
Thanks.
Here is the process for generating the model:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.2.006">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process">
<process expanded="true" height="971" width="815">
<operator activated="false" class="read_excel" compatibility="5.2.006" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
<parameter key="excel_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\pubs_500energy.xlsx"/>
<parameter key="imported_cell_range" value="A1:F401"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<list key="data_set_meta_data_information">
<parameter key="0" value="pub_id.true.integer.id"/>
<parameter key="1" value="title.true.text.attribute"/>
<parameter key="2" value="journal.true.text.attribute"/>
<parameter key="3" value="keyword_plus.true.text.attribute"/>
<parameter key="4" value="abstract.true.text.attribute"/>
<parameter key="5" value="energy.true.binominal.label"/>
</list>
</operator>
<operator activated="false" class="text:data_to_documents" compatibility="5.2.003" expanded="true" height="60" name="Data to Documents" width="90" x="45" y="120">
<list key="specify_weights"/>
</operator>
<operator activated="false" class="read_excel" compatibility="5.2.006" expanded="true" height="60" name="Read Excel (2)" width="90" x="45" y="255">
<parameter key="excel_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\pubs_500energy_withkeywords_2012-07-10.xlsx"/>
<parameter key="imported_cell_range" value="A1:AB501"/>
</list>
<parameter key="0" value="pub_id.true.integer.label"/>
<parameter key="1" value="photovolt.true.binominal.attribute"/>
<parameter key="2" value="solar energy.true.binominal.attribute"/>
<parameter key="3" value="energy production.true.binominal.attribute"/>
<parameter key="4" value="renewable energy.true.binominal.attribute"/>
<parameter key="5" value="energy storage.true.binominal.attribute"/>
<parameter key="6" value="fuel cell.true.binominal.attribute"/>
<parameter key="7" value="batter.true.binominal.attribute"/>
<parameter key="8" value="energy conversion technolog.true.binominal.attribute"/>
<parameter key="9" value="solar cell.true.binominal.attribute"/>
<parameter key="10" value="solar fuel.true.binominal.attribute"/>
<parameter key="11" value="biofuel.true.binominal.attribute"/>
<parameter key="12" value="alternative energy.true.binominal.attribute"/>
<parameter key="13" value="sustainable energy.true.binominal.attribute"/>
<parameter key="14" value="solar-energy.true.binominal.attribute"/>
<parameter key="15" value="fuel-cell.true.binominal.attribute"/>
<parameter key="16" value="hydrogen storage.true.binominal.attribute"/>
<parameter key="17" value="artificial photosynthesis.true.binominal.attribute"/>
<parameter key="18" value="h2 storage.true.binominal.attribute"/>
<parameter key="19" value="energy application.true.binominal.attribute"/>
<parameter key="20" value="power generation.true.binominal.attribute"/>
<parameter key="21" value="solar hydrogen.true.binominal.attribute"/>
<parameter key="22" value="biodiesel.true.binominal.attribute"/>
<parameter key="23" value="energy generation.true.binominal.attribute"/>
<parameter key="24" value="fuel.true.binominal.attribute"/>
<parameter key="25" value="light harvesting.true.binominal.attribute"/>
<parameter key="26" value="light-harvesting.true.binominal.attribute"/>
<parameter key="27" value="keyword energy.true.binominal.attribute"/>
</list>
</operator>
<operator activated="false" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="Set Role (3)" width="90" x="121" y="322">
<parameter key="name" value="pub_id"/>
<parameter key="target_role" value="id"/>
<list key="set_additional_roles"/>
</operator>
<operator activated="false" class="text:process_documents" compatibility="5.2.003" expanded="true" height="94" name="Process Documents" width="90" x="179" y="30">
<parameter key="prune_method" value="percentual"/>
<parameter key="prunde_below_percent" value="1.0"/>
<parameter key="prune_above_percent" value="70.0"/>
<parameter key="prune_below_absolute" value="2"/>
<parameter key="prune_above_absolute" value="888"/>
<process expanded="true" height="422" width="634">
<operator activated="false" class="text:tokenize" compatibility="5.2.003" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/>
<operator activated="false" class="text:transform_cases" compatibility="5.2.003" expanded="true" height="60" name="Transform Cases" width="90" x="70" y="150"/>
<operator activated="false" class="text:filter_stopwords_english" compatibility="5.2.003" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="102" y="226"/>
<operator activated="false" class="text:filter_by_length" compatibility="5.2.003" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="232" y="224">
<parameter key="min_chars" value="2"/>
<parameter key="max_chars" value="888"/>
</operator>
<operator activated="false" class="text:stem_snowball" compatibility="5.2.003" expanded="true" height="60" name="Stem (Snowball)" width="90" x="372" y="189"/>
<operator activated="false" class="text:generate_n_grams_terms" compatibility="5.2.003" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="501" y="158">
<parameter key="max_length" value="3"/>
</operator>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Snowball)" to_port="document"/>
<connect from_op="Stem (Snowball)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<operator activated="false" class="write" compatibility="5.2.006" expanded="true" height="60" name="Write" width="90" x="179" y="165">
<parameter key="object_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\wordlist_500Energy"/>
</operator>
<operator activated="false" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="Set Role (2)" width="90" x="313" y="30">
</operator>
<operator activated="false" class="join" compatibility="5.2.006" expanded="true" height="76" name="Join" width="90" x="246" y="300">
<list key="key_attributes"/>
</operator>
<operator activated="false" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="Set Role" width="90" x="380" y="300">
<parameter key="name" value="energy"/>
<parameter key="target_role" value="label"/>
</operator>
<operator activated="false" class="generate_weight_stratification" compatibility="5.2.006" expanded="true" height="76" name="Generate Weight (Stratification)" width="90" x="447" y="30"/>
<operator activated="false" class="x_validation" compatibility="5.2.006" expanded="true" height="112" name="Validation" width="90" x="514" y="165">
<process expanded="true" height="422" width="292">
<operator activated="false" class="naive_bayes" compatibility="5.2.006" expanded="true" height="76" name="Naive Bayes" width="90" x="84" y="26"/>
<connect from_port="training" to_op="Naive Bayes" to_port="training set"/>
<connect from_op="Naive Bayes" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
<portSpacing port="sink_through 1" spacing="0"/>
</process>
<operator activated="false" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
</operator>
<operator activated="false" class="performance_binominal_classification" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="source_model" spacing="0"/>
<portSpacing port="source_test set" spacing="0"/>
<portSpacing port="source_through 1" spacing="0"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
</operator>
<operator activated="false" class="write_model" compatibility="5.2.006" expanded="true" height="60" name="Write Model" width="90" x="581" y="30">
<parameter key="model_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\model_500Energy_NaiveBayes"/>
</operator>
<connect from_op="Read Excel" from_port="output" to_op="Data to Documents" to_port="example set"/>
<connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Read Excel (2)" from_port="output" to_op="Set Role (3)" to_port="example set input"/>
<connect from_op="Set Role (3)" from_port="example set output" to_op="Join" to_port="right"/>
<connect from_op="Process Documents" from_port="example set" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Process Documents" from_port="word list" to_op="Write" to_port="object"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Join" to_port="left"/>
<connect from_op="Join" from_port="join" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Generate Weight (Stratification)" to_port="example set input"/>
<connect from_op="Generate Weight (Stratification)" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_op="Write Model" to_port="input"/>
<portSpacing port="sink_result 3" spacing="0"/>
</process>
</operator>
</process>
And here is the code for applying the model to new documents for categorization:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>Not sure how I would post the data. The model is based on a set of 500 documents with 4 text attributes, an id (pub_id), and a label (energy); these are joined with a set of binomial attributes indicating whether specific keywords are contained in the document. Happy to provide more information.
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="read_model" compatibility="5.2.006" expanded="true" height="60" name="Read Model" width="90" x="514" y="435">
</operator>
<operator activated="true" class="read_excel" compatibility="5.2.006" expanded="true" height="60" name="Read Excel (3)" width="90" x="12" y="467">
<parameter key="excel_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\cat100new_2012-07-11.xlsx"/>
<parameter key="imported_cell_range" value="A1:E101"/>
</list>
</list>
</operator>
<operator activated="true" class="text:data_to_documents" compatibility="5.2.003" expanded="true" height="60" name="Data to Documents (2)" width="90" x="112" y="525">
</operator>
<operator activated="true" class="read" compatibility="5.2.006" expanded="true" height="60" name="Read" width="90" x="112" y="435">
<parameter key="io_object" value="WordList"/>
</operator>
<operator activated="true" class="text:process_documents" compatibility="5.2.003" expanded="true" height="94" name="Process Documents (2)" width="90" x="246" y="525">
<process expanded="true" height="404" width="643">
<operator activated="true" class="text:tokenize" compatibility="5.2.003" expanded="true" height="60" name="Tokenize (2)" width="90" x="45" y="30"/>
<operator activated="true" class="text:transform_cases" compatibility="5.2.003" expanded="true" height="60" name="Transform Cases (2)" width="90" x="180" y="30"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.003" expanded="true" height="60" name="Filter Stopwords (2)" width="90" x="315" y="30"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.2.003" expanded="true" height="60" name="Filter Tokens (2)" width="90" x="450" y="30">
</operator>
<operator activated="true" class="text:stem_snowball" compatibility="5.2.003" expanded="true" height="60" name="Stem (2)" width="90" x="380" y="165"/>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.003" expanded="true" height="60" name="Generate n-Grams (2)" width="90" x="447" y="255">
</operator>
<connect from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/>
<connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
<connect from_op="Filter Stopwords (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
<connect from_op="Filter Tokens (2)" from_port="document" to_op="Stem (2)" to_port="document"/>
<connect from_op="Stem (2)" from_port="document" to_op="Generate n-Grams (2)" to_port="document"/>
<connect from_op="Generate n-Grams (2)" from_port="document" to_port="document 1"/>
</process>
</operator>
<operator activated="true" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="Set Role (4)" width="90" x="380" y="570">
</operator>
<operator activated="true" class="read_excel" compatibility="5.2.006" expanded="true" height="60" name="Read Excel (4)" width="90" x="43" y="660">
<parameter key="excel_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\cat100new_withkeywords_2012-07-11.xlsx"/>
<parameter key="imported_cell_range" value="A1:AB101"/>
</list>
</list>
</operator>
<operator activated="true" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="Set Role (5)" width="90" x="178" y="660">
</operator>
<operator activated="true" class="join" compatibility="5.2.006" expanded="true" height="76" name="Join (2)" width="90" x="447" y="705">
</operator>
<operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model (2)" width="90" x="648" y="525">
</operator>
<connect from_op="Read Model" from_port="output" to_op="Apply Model (2)" to_port="model"/>
<connect from_op="Read Excel (3)" from_port="output" to_op="Data to Documents (2)" to_port="example set"/>
<connect from_op="Data to Documents (2)" from_port="documents" to_op="Process Documents (2)" to_port="documents 1"/>
<connect from_op="Read" from_port="output" to_op="Process Documents (2)" to_port="word list"/>
<connect from_op="Process Documents (2)" from_port="example set" to_op="Set Role (4)" to_port="example set input"/>
<connect from_op="Set Role (4)" from_port="example set output" to_op="Join (2)" to_port="left"/>
<connect from_op="Read Excel (4)" from_port="output" to_op="Set Role (5)" to_port="example set input"/>
<connect from_op="Set Role (5)" from_port="example set output" to_op="Join (2)" to_port="right"/>
<connect from_op="Join (2)" from_port="join" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 1"/>
<connect from_op="Apply Model (2)" from_port="model" to_port="result 2"/>
</process>
</operator>
</process>
In case this provides pertinent information:
W-BayesLogisticRegression also only gives binary confidences whereas W-BayesNet does give non-0/1 confidences but all of the documents classified as irrelevant have the same confidence, with a little more variation for those classified as relevant.
I am currently using a sample of 500 documents that have been coded relevant/irrelevant and I am using the model to predict 100 new documents.
And here's a simpler version of the process that suffers from the sample problem:
To generate the model:
If there’s any other information that would help shed light on this, please let me know.
Thanks!
<?xml version="1.0" encoding="UTF-8" standalone="no"?>And to apply model to new data set:
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="read_excel" compatibility="5.2.006" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
<parameter key="imported_cell_range" value="A1:F501"/>
</list>
</list>
</operator>
<operator activated="true" class="text:data_to_documents" compatibility="5.2.003" expanded="true" height="60" name="Data to Documents" width="90" x="45" y="120">
</operator>
<operator activated="true" class="text:process_documents" compatibility="5.2.003" expanded="true" height="94" name="Process Documents" width="90" x="179" y="30">
<operator activated="true" class="text:tokenize" compatibility="5.2.003" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/>
<operator activated="true" class="text:transform_cases" compatibility="5.2.003" expanded="true" height="60" name="Transform Cases" width="90" x="70" y="150"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.003" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="102" y="226"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.2.003" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="232" y="224">
</operator>
<operator activated="true" class="text:stem_snowball" compatibility="5.2.003" expanded="true" height="60" name="Stem (Snowball)" width="90" x="372" y="189"/>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.003" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="501" y="158">
</operator>
</process>
</operator>
<operator activated="true" class="write" compatibility="5.2.006" expanded="true" height="60" name="Write" width="90" x="179" y="165">
</operator>
<operator activated="true" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="Set Role" width="90" x="313" y="75">
</operator>
<operator activated="true" class="generate_weight_stratification" compatibility="5.2.006" expanded="true" height="76" name="Generate Weight (Stratification)" width="90" x="447" y="30"/>
<operator activated="true" class="x_validation" compatibility="5.2.006" expanded="true" height="112" name="Validation" width="90" x="514" y="165">
<operator activated="true" class="naive_bayes" compatibility="5.2.006" expanded="true" height="76" name="Naive Bayes" width="90" x="64" y="36"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
</operator>
<operator activated="true" class="performance_binominal_classification" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/>
</process>
</operator>
<operator activated="true" class="write_model" compatibility="5.2.006" expanded="true" height="60" name="Write Model" width="90" x="581" y="30">
<parameter key="model_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\model_500Energy_NaiveBayesNoKW"/>
</operator>
<connect from_op="Process Documents" from_port="example set" to_op="Set Role" to_port="example set input"/>
<connect from_op="Validation" from_port="training" to_port="result 1"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
</process>
</operator>
</process>
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
</list>
</list>
</operator>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
<connect from_op="Process Documents (2)" from_port="example set" to_op="Apply Model (2)" to_port="unlabelled data"/>
</process>
</operator>
</process>
Thanks!
Best,
Marius
