[SOLVED] Controlling map order of nominal values
A "map order" is alluded to in the tooltip of the "sort alphabetically" parameter of the Removed Unused Values operator.
Premise 1:
A set of nominal values has an inherent "map order".
Premise2:
This "map order" determines the sequence in which elements are arranged on a chart axis, when a nominal attribute is selected for that axis (e.g. bubble chart with nominal x-axis attribute).
Question1:
Are the premises above correct?
Question2:
Other than the "sort alphabetically" mechanism of the Remove Unused Values Operator, are there any ways to control the "map order"? (...in order to control subsequent chart axis order for nominal attributes.)
Premise 1:
Premise2:
Question1:
Question2:
1 - 6 of
61
HI Marius,
Is it possible In Advanced Charts to plot multiple binomial values on the Nominal axis?
The error message "Mixed nominal values on axis ... All nominal series configurations on an axis must refer to the.same nominal mapping..." suggests this.
I have to two binominal attributes with value range {true, false}, used the "Remap Binomials" to define false as negative and true as positive, but that does not result in the same nominal mapping.
Thanks,
Bart
Thanks,
Bart
For anyone else who needs this in future:
One way to reorder nominal values is to reorder the exampleset, and then perform a trivial (i.e. identity) Generate Attributes operation on the attribute in question.
In the example below, compare eg x vs x scatter chart of the two outputs.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="641" width="1048">
<operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="244" y="102">
<list key="attribute_values">
<parameter key="x" value=""b""/>
</list>
<list key="set_additional_roles"/>
</operator>
<operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="246" y="210">
<parameter key="x" value=""a""/>
</list>
</operator>
<operator activated="true" class="append" compatibility="5.2.008" expanded="true" height="94" name="Append" width="90" x="514" y="165"/>
<operator activated="true" class="sort" compatibility="5.2.008" expanded="true" height="76" name="Sort" width="90" x="648" y="165">
<parameter key="attribute_name" value="x"/>
</operator>
<operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes" width="90" x="782" y="165">
<list key="function_descriptions">
<parameter key="x" value="x"/>
</list>
</operator>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/>
<connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/>
<connect from_op="Append" from_port="merged set" to_op="Sort" to_port="example set input"/>
<connect from_op="Sort" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
<connect from_op="Generate Attributes" from_port="original" to_port="result 2"/>
<portSpacing port="sink_result 1" spacing="126"/>
<portSpacing port="sink_result 3" spacing="0"/>
</process>
</operator>
</process>
in RapidMiner, nominal values are represented internally as integer values which are mapped to strings during display and model creation etc. This is for reducing the memory consumption, since instead of storing over and over again the same (probably long) strings, storing just numbers and a mapping usually leaves a smaller memory footprint.
When RapidMiner reads data, it maps the first string in a column to "0", the second one to "1" etc. So the only possibility to control the ordering of the mapping is by ordering your input data. Btw, if you are using the new "adavanced charts" instead of the "plot view", nominal values are always sorted alphabetically.
Best,
Marius
